SOLD: Aston Martin DB9 caliper bracket adapter carrier for 345mm disc
    This front brake adaption kit allows the fitment of Aston Martin DB9 Calipers to your E46 M3.
    I previously had a full set I purchased from Vagbremtechnic and there was a safety recall on the aluminum carriers. These new ones are high strength zinc coated steel.
    What you see is what you get.
    Click image for larger version  Name:	DB9.jpg Views:	117 Size:	95.4 KB ID:	267093
    Epsilon, to confirm, these don't require the spacer to run a 345 disc?
      You are probably right. When they asked me about the disc setup, they noted that it was for the bolt length.
      Unfortunately, I don't have the spacers. Without them, this makes it compatible with the stock 325mm disc setup.
      Make offer.
        I'll send PM
