Dinan Throttle Bodies for E46 M3
    Originally posted by Advorsor View Post
    I have the Dinan set. Was able to get it on eBay like 2 years ago for $1,500(?) I think. They come up every now and then there + MPWW. Or you could do this as an alternative: https://store.vacmotorsports.com/vac...s54-p2430.aspx
    Advorsor, I'd like to visit with someone who's running the bored VAC t-bodies. VAC lists them as "V.2", almost insinuating these are a second generation version. Was there a previous generation which they upgraded?
    Anyone running the VAC enlarged throttle bodies, who'd like to jump in?
    Feff
    MVP Track Time
      Someone is inevitably going to come in here and talk-down VAC products. I personally never had a problem but YMMV. I don't know anyone who has these so GL there but its really just boring out the TBs. I would think they are competent enough to do that..
        Is not the closing plate also custom to seal the TB? Though simple in principle I am sure is a precision job. But I would think a proper machine shop would be able to do it to spec.
          Originally posted by Feffman View Post
          I called Dinan directly and they no longer produce the-t-bodies for the E46 M3, nor will they do a one-off single set or group deal.
          My new racing S54 has head work, larger cams, exhaust, etc. to run to 8,500RPM (ish) so the larger t-bodies will help with a bit more than 1HP, I hope. SCCA just approved the larger ported bodies for class T1 for the S54.
          Feff
          It won't brotha.
          A number of us have tried this out about 9 years ago. Full built heads, ssv1 systems, cams, etc... 3-5 hp is the result when dynoing only the TB difference back to back.
            That would be great if we could find a good source who can do the job to Normal M3 TB's.
            VAC can do them. I'm sure you guys can get a group buy going. It would be better just doing a GB for Stage 2 head or something. About the same cost and more benefit
              Hugh Stewart, SCCA T1 racer extraordinaire, of Hi-Speed Motorsports (https://www.facebook.com/hispeedmotorsports) is taking up the mantle with dyno numbers before and after boring. It may be a few weeks, but he's promised me detailed information on the results.
              Feff
              MVP Track Time
                Feff
                Whats the pricing? Is there a core charge,
                  Hi-Speed Motorsports is not doing the boring on the t-bodies. Hugh is sending them out to be bored and then he's doing before and after dyno testing.
                  Feff
                  MVP Track Time
                    Is he willing to share the shop doing the work or information on the work so people can get it done with a shop more local to them? Pending good dyno results it sounds like this could become a popular mod...
                    2003 LSB/LSB 6MT Coupe | BUILDJOURNAL | CAE RACING | DMG AUTOSPORT | SUPERSPRINT | 996 BREMBO BBK | ENKEI | RAYS ENGINEERING | MOTORSPORT HARDWARE | OHLINS | GROUND CONTROL | BIMMERWORLD | TURNER MOTORSPORT | REDISH MOTORSPORT | DR VANOS | BEISAN
                      Hugh has sent them to Crest Automotive (https://www.catune.co.uk/category-Y2...lPWU0Nm0=.html) for the throttle boring. I believe they do a 1.5mm bore.
                      Feff
                      MVP Track Time
                        Appreciate the info. Will be looking forward to the dyno results. A new thread in the main forum could be useful for that discussion.
                          Feffman I’m curious to see the results myself!
                            Feffman Here's a set for sale in Las Vegas.
                              No link
                              M-texture (F2AT) - Turner CSL V2/CatCams 280 272/SSv1/SS Sec1/Sec2 dual res/SCZA TI (raw) - FatCat stage 3 ult 400f/784r - Vorshlag - EC7r 18x9.5 ET35/CRS 275/35/18 - RacingBrake BBK/MileEnd CSL bumper/Vorsteiner Trunk/Cobra Nogaro Circuit Mtexture/GC RCA/YURKan Cages/Hotchkiss/Vibra-technics/
                                No link
                                They sold
                                More Power (E46 M3 & E85 E86 Z4M): + 6 HP @ 7900 RPM, + 4 LB-FT @ 7900 RPM (coupled w/ engine software) More Power (E36/7 Z3M 528i): + 4 HP @ 6500 RPM, + 3 LB-FT @ 6000 RPM (coupled w/ engine...
