SOLD: SME RACP X Brace
    Selling my white powder coated SME x brace as I sold the car and the buyer didn't want it. Worked great to secure the rear subframe mounts to the shock tower/frame rail and add some rigidity to the rear. Has some marring from junk in the trunk, but otherwise fine. Weighs only 6.4lb.
    $SOLD
    SME (Specialised Motorsport Engineering) have designed this brace to be the lightest and strongest on the market, and unlike other available braces it truly strengthens the E46’s weak rear axle carrier panel. Precision fabricated from Chromoly, this brace only weighs 3kg and is a simple install – no welding required, just a small amount of drilling to allow access to the RACP from above. Kit comes complete with drilling jig and instructions. New bolts then drop all the way through to the subframe for a truly braced outcome unlike rival products which simply bolt to the skin above the RACP. Fitting instructions can be found on the previous page to give more insight into what is involved.   The SME E46 RACP Brace strengthens the rear end of the E46 BMW, which is a known weakpoint. Made from Chromoly material and supplied in one piece, the brace weighs just 3KG!
    Just got it boxed up if you want to check shipping costs
    45 x 11 x 4 inches
    8lb 8oz
    Shipping from 28216
    Hello is this still available? I'm interested in getting it
      Yep it's ready to go. Note that it's priced so low because it does not include hardware, which can be ordered directly from SME if you need it:
      Price for two Bolts, two Nuts and two washers.    M12x1.5, L= 150mm, Din 10,9 (same as standard)
      NVM it just sold on fb
