S54 & E46 Part out
    S54 & E46 Part out
    ***If its not specifically listed then its not available, sorry.
    I was originally making this post for an engine I parted out but I think I'll just make this a continuous part out and misc items for sale thread.
    I've disassembled an S54 that dropped a valve. Pretty much everything is available except the block, head, plenum and rod/pistons. All prices are obo plus shipping. Payment via Zelle or cash in person, I realize that is not normal considering all the internet scams but I have plenty of history here and if you don't trust me then you don't have to buy the parts, no worries. I've got more pics of everything so if you see something you are interested in send me a message.
    • Oil pump - $300 - Definitely ate some metal but I pulled it all apart and it really doesn't look bad. The regulator piston has some scratches and slides freely, but I'd probably want to get the DLC coated one from the SMG shop in Europe.
    • Crankshaft - $800 - No bearing issues, they all looked great, no damage, just a good solid used crank
    • Oil pan and pickup tubes - $600 - no issues
    • Throttle Body assembly - $500 - The engine spit some metal out the #1 cyl so it does need some cleaning but should be fine with no issues.
    • MSS54 DME - $500 - SOLD
    • Timing Cover - $40
    • Coolant Pipe - $40 - 11537838756
    • Coolant Pipe - $40 - 11537830711
    • Water pump - $60 - 2017 date code
    • Thermostat Housing - $50
    • W/P Pulley - $25 - 11517840403
    • Crank Pulley - $50 - 11217840380
    • P/S Pulley - $40 - 32427830838
    • Valve Cover - $100
    • Dipstick & Tube - $50
    • Valve Cover trim - $60 - 11127835905
    • Air Filter box, Elbow and MAF - $200 - 13717853879
    • Cams - $50 - 7832194 & 7832195
    • Cams - $50 - 7833223 & 7833225
    • Throttle body assembly with injectors, fuel rail and idle air rail - $600
    Carbon Fiber trim, part numbers are for the stock part
    • Inner door handles - $200 - 51418222705 & 51418222706, 1 tab broken, but doesn't look like it should affect fitment
    • Steering Wheel lower trim - $100 - 32347833355
    • E-Box Cover - $300 - 12901436443
    • IHKA and storage partition (Nav compatible) - $400 - 51167001410
    • Cupholder - $165 - 51168217953 - Forward tabs broken
    • SMG Steering wheel paddles - $90 - 32347891004 - I think these are AutoTechnik brand?
    New parts:
    • 11617833498 - $1000 - CSL Intake Snorkel - SOLD
    • 11247835452 - $230 - +0.25 Rod Bearings x6
    • 11247835451 - $230 - +0.25 Rod Bearings x6
    • 11211706847 - $290 - Main Bearings x12
    • 11212241935 - $70 - Main Thrust Bearing x2
    • 11317830887 - $28 each - Rocker Arm Clips, 4 available
    • 11337833259 - $77 each - Rocker arms, 5 available
    • 11347830888 - $67 each - Exhaust Valves, 3 available
    • 11411317284 - $70 - Oil Pump Sprocket
    • 11417834889 - $72 - Oil Pump Pickup Tube
    • 11137834885 - $66 - Oil Pump pick up screen
    • 11137838130 - $850 - Oil Pan
    • 11111318185 - $40 - CPV
    • 34112282416 - $165 - Front brake pads
    • 33411090505 - $85 - Rear wheel bearing
    • 33412229120 - $139 - Rear wheel hub
    • 31122229623 - $96 - LF LCA Bracket
    • 31122229453 & 31122229454 - $800 - Front LCA, some rust on ball joints, but I don't think it will affect their use
    • 34212282303 & 34212282304 - $800 - CSL Brake rotors, some rust on surfaces but should clean up.
    I'll start continuously updating this thread as I go.
    Email to [email protected]
    Welp - more parts that I don't technically need yet but I'm going to buy. DM coming your way.
      PM’d about the intake!
        I haven't done a great job of keeping this thread up to date, looking to move these parts, make an offer if you have interest.
          What exactly is an e-box cover? Sorry for my ignorance, but interested if it’s something that works for E46 non-M
            BADCLOWN electronics box, where the DME is housed.
            They are physically the same for all E46s the only difference is whether your box has the 5mm allen machine screw of the T25 coarse thread screw.
              Gotcha, thanks for the explanation. I’m interested in the piece but I’ll keep an eye on it
                Do you have headers for sale?
                  TB's added
                    is the valve cover gasket new, is it OE and does it come with the rest of the seals? price?
                      6speedS54 Sold.
