Hey all,
I haven't had the time to install this kit that I've prepared and haven't been driving much, so thinking about letting it go. Includes the following:
- 996 front and rear calipers with 40k miles from Rennlist -- machined 5.5 mm (for ZCP rotors) by Rally Road. Original paint with Brembo decals + high temp VHT clear over them applied by myself
- Rally Road front and rear brackets + hardware (fronts, rears)
- Creations Motorsports front and rear SS brake lines (these and these)
- New Porsche Textar front and rear pads (rears are Boxster (?) front pad shape -- the ones that sweep the whole rotor -- these + these) - New Porsche OE bleeders all around and pad retainer clips (4x this, 1x this 1x this)
Basically everything you need for the install minus ZCP rotors. Calipers were in great shape when I received them minus a few rock chips which I filled in with VHT high temp red that didn't quite match .. I figured it wouldn't be noticeable installed. I'll include a bottle of red model paint that everyone says matches perfectly if you want to fix, personally I preferred the higher temp paint. I also wet sanded off the Porsche logo and applied Brembo decals, and put VHT high temp clear over them (still has OE paint underneath). Slight clear coat lines where I taped off the rest of the caliper that can either be ignored or polished down (I opted for ignore, again would be invisible installed). Or you can strip and refinish like many do, but I think they look great as is.
SOLD
SOLD
