Various Springs
    For Sale: Various Springs
    I have pairs of various springs that I've acquired over the years that I no longer have a use for.
    $85 shipped per pair
    Brand: H&R
    PN: 160-60-080
    Diameter: 60mm
    Height: 160mm
    Spring Rate: 457lbs
    Brand: Eibach
    PN: ES0600.250.0450
    Diameter: 2.5 inch
    Height: 6 inch
    Spring Rate: 450lbs
    Brand: Eibach / Ground Control
    PN: GC125.64.116
    Diameter: 2.5 inch
    Height: 5 inch
    Spring Rate: 660lbs
    Bump $80 shipped
      Bump $75 shipped
        How did the 660# spring work out? What was the setup?
        Recently went aero and would like to test a stiffer rear spring. Currently on 550 rear and feels pretty balanced with some room to give in the rear.
          The 660 are actually from when I had them on my z3m coupe. My current car has 600lbs in the rear, however the Eibach coilovers my car came with feel underdamped so I can't give you a good verdict.
          What suspension setup are you on? Plenty of people run 650lbs and higher in the rear and like it quite a lot, but it depends on a variety of factors.
            fullyflaredd
            ​​​​​​​I was about to reply to your thread on bimmerforums, but assumed you're the same as "Dasmeth"?
            Are the ES0600.250.0400 still available? I can't find specs on them though - did you ever get their travel and block heights?
            Thanks
              Tbonem3
              ​​​​​​​Yep, that's me on bimmerforums.
              Still available. Unsure of travel and block heights, was not able to find that info online.
                Ok I think I'll take them. I'll pm you tomorrow.
                  Bump!
