IND | Eventuri E46 M3 Hybrid Carbon Airbox System
    After two years of engineering work, Eventuri’s highly anticipated E46 M3 Hybrid Carbon Airbox System is here and ready to transform the S54 experience. This innovative system delivers the iconic CSL induction sound while retaining full MAF sensor functionality, preserving smooth and reliable factory driveability. No Alpha-N conversion, no expensive retuning required. Just pure sound and performance.
    This is the first intake system that gives E46 M3 owners true CSL audio with OEM-level drivability in a fully plug-and-play design.
    Available Part Numbers
    • EVE-E46ABX-CF-INT • Hybrid Carbon Airbox with Full Eventuri Intake
    • EVE-E46ABX-CF-PLM • Hybrid Carbon Airbox Only (reuse existing Eventuri intake)
    Eventuri offers two configurations to support both new customers and those already running an Eventuri intake. Each component is developed to maximize airflow efficiency, boost induction resonance, and maintain long-term structural integrity.
    Full Hybrid Airbox + Intake Includes
    • Carbon fiber main airbox
    • Carbon fiber snorkel with integrated MAF tube
    • Thermoplastic trumpets with CNC stainless reinforcement rings
    • Carbon fiber filter housing + dry high-flow filter
    • Carbon fiber cold air scoop
    • Stainless steel brackets + flanges
    • CNC machined breather adapters
    • Custom EPDM flexible coupler
    • Silicone couplers
    • Crankcase breather hose and vacuum lines
    EVE-E46ABX-CF-INT
    EVE-E46ABX-CF-PLM
    Main Airbox Assembly
    The prepreg carbon main airbox is built to resonate under load, achieving the unmistakable CSL roar. Mechanical fasteners and gaskets maintain airtight sealing through extreme heat cycles and vibration for long-term reliability.
    Precision molded trumpets deliver smooth internal airflow surfaces and perfect geometry. Stainless reinforcement rings prevent deformation at the coupler junction.
    Airbox Snorke​l
    The snorkel efficiently channels airflow into the trumpets while securing the OEM MAF sensor to a CNC machined boss for accurate metering.
    CFD-Optimized Design
    Multiple CFD simulations were used to refine geometry and ensure each cylinder receives consistent airflow under all load conditions.
    Intake Housing Assembly
    Eventuri’s Generation 2 dry filter sits reverse-mounted inside a carbon shroud to remove turbulence and reduce pressure drop across the entire intake tract.
    Cold Air Scoop
    The lightweight carbon scoop forces dense ambient air directly toward the intake while still allowing airflow through the brake duct.
    Full Assembly Views
    Now Available at IND Distribution
    Both versions of the Eventuri E46 M3 Hybrid Carbon Airbox System are available to order now directly through IND, with inventory allocated for customers upgrading to the full experience or completing their existing Eventuri intake setup.
    The Eventuri E46 M3 Hybrid Carbon Airbox System may be viewed at the following link to our online store:
    https://ind-distribution.com/collect...ox-with-intake
    Please contact IND by phone or email for more information or to place your order.
    866.963.4520 | [email protected]
    IND DISTRIBUTION | 847-963-4520 • INSTAGRAM • FACEBOOK • YOUTUBE • FLICKR
    This looks absolutely amazing! Too bad it's way out of my college student budget 😂 I'd love to get it eventually though!
      Looks really nice and I was following this when I learned about it three weeks ago. However, $2,918.06 total cost in the cart is a hard pill to swallow for the "existing Eventuri intake owners" option. Karbonius OEM Style airbox is $1700 prior to tax and the Turner airbox kit is $2,174.99 prior to tax and tune. I would have instantly bought this without hearing customer-installed videos if this was priced at $2000ish out the door. I'll keep enjoying the normal Eventuri intake sounds and occasionally check Eventuri for any price decreases which imo they need to do to stay competitive.
        Order placed! Very excited.
          Any price consideration for NAM3 forum members? Thanks.
            Agreed the price tag hurts. Really love the plug and play though. Conflicted for sure, as I'm in the boat of not wanting to get into the tune and additional work for full CSL box. 🥲
              Update on timing of shipping the units for placed orders?
                What I’d love to know, is what they are doing with the CSL bumper hole since the cold air scoop is not compatible. Is the factory CSL scoop retained instead?
                2006 E46 M3 Interlagos Blue ZCP Slicktop "CS"
                  Hello all. We apologize for the lack of reply. We've spent the last several months building out and launching a revised website last month and then everything that goes into the Black Friday weekend promotion has kept us extremely busy. Not necessarily a valid excuse for the lack of updates, but we wanted to provide some background.
                  That said, to address some of the questions/comments:
                  The Eventuri Intake Kit with scoop is designed for the standard M3 front bumper with brake ducts. Obviously the CSL bumper is an extremely popular upgrade and was included on the Eventuri new airbox system demo car as well, so yes, if you're running a CSL front bumper, while the Eventuri Scoop is not compatible, BMW's OE CSL bumper inlet elbow duct simply feeds cool air to the front of the intake filter housing area.
                  We understand pricing will never be perfect for everyone, but hopefully the different options on the market will cater to different budgets. That said, pricing is set by the manufacturer.
                  Eventuri produced their new airbox system with modularity in mind and direct fitment to their existing E46 M3 carbon intake kit along with including items like a correct CSL length crankcase vent hose, air shut-off valve hose, and wouldn't require the switch from MAF to IAT sensor with corresponding harness and software. The E46 M3 Intake and CSL options we offer and corresponding retails are as follows: (for 6MT cars; added cost for SMG CSL reservoir/bracket)
                  • $1070: Standard Eventuri Carbon Intake Kit
                  • $2769: IND Carbon Intake Package with Karbonius OEM style carbon airbox and Eventuri Intake Kit
                  • $3150: Complete Eventuri Airbox System with Intake System
                  • $3700+software: Karbonius CSL Airbox & Snorkel, OE crankcase hose/air shutoff valve/IAT sensor/BMC air filter, and MAF conversion harness
                  Granted the CSL airbox costs can grow if you elect to also get a CSL or modified air rail and MAP sensor.
                  We're working on getting ETAs from Eventuri.
                    Did black friday sales apply to this airbox?
                      Niceeeee
