I fitted KW V3s to my car round christmas last year, but Ive only just started to use the car properly again.
I set the bump and rebound to KW's reccommended spec, which I found superb to start with, but the more Ive used the car, the more I found it was a bit hard and didnt soak up bumps.
Since then Ive adjusted everything to basically the softest setting on both bump and rebound. The ride is now perfect comfort wise, but the car now doesnt seem as stable - particularly at higher speeds. Ive noticed when over taking and pulling back in, the car seems to float quite a bit. I have a basic understanding of how the susp works, and I believe this is caused by me now running more on the springs, and apposed to the dampers/ shockers.
Is it possible to keep the softness of my current settings, but bring back that planted / stable feel I had before. Or is it a case of compromising one to improve t'other.
Cheers :thumbs:
ps. Ive found this guide quite useful... http://www.koni-na.com/pdfcatalogs/K...ortCatalog.pdf
Cheers :thumbs:
