Originally posted by mark csl
Doing it the way you are doing the lacquer you've put on will PEEL straight off the monent it is put onto the bumper (The first time I did this it was also with a lacquer without a hardener mix in it and it peeled straight off the moment it went on the bumper due to flexing of the splitters to fit). You need a hardener mix in the lacquer for it to stick properly.
ALSO
I wouldn't have rubbed it down to bare carbon fiber - the carbon fiber from the factory has a coating on it to stop the lacquer from soaking through it because carbon fiber is porous and you'll end up just laying coats and coats of it onto the splitters and you'll still not get that flat finish (you'll get a weaved look to the finish)
The factory splitters have a maximum of 2 coats on it only - it's very very thin - and this is only achievable with the stop coating on it.
