Clutch / Gearbox
    Clutch / Gearbox
    Hi,
    I can not help but notice that over the last
    few months as many of the CSL's start
    to put on the miles, and there appears
    quite a few using them repeatedly on the Track as well,
    that Clutch and gearbox issues are starting
    to become more or less the norm.
    Many good points and useful observations
    have been made, but it all feels a bit like
    putting a 'plaster' over the wider issues and
    hoping it will either go away or just sort
    of fix itself.
    The element of wear on the many components
    involved in the SMG 11 process is unhelpful
    as the mileage starts to increase, as with all
    things of this design.
    But the word 'Slur' really meaning slip is now
    a common issue with many owners and drivers.
    Just wondering if with the information, resources,
    and the Technical data available, via this Forum,
    that some sort of 'remeadial' or 'to do' type
    info sheet could be prepared, or anything else
    that that others feel may assist.
    Just wondering how others viewed this.
    I suppose if I see about 20 CSL cars for sale
    shortly then I know what the common consenses
    is !!
    Regards,
    The Gorilla.
    I would be a good idea I think, I for one am someone who is suffering from this supposed 'slur' or as you say clutch slip, I tried the car in S6 with the DSC off this morning and it made no difference to how the car changed gear, there is constantly a slip and it's always there now, the only thing that makes it better is me lifting off on upshifts which tends I feel to put less strain on the car in general.
    I'm not particularly impressed with this, a 60k car and huge manufacturer it should be spot on IMO, for BMW to have no real solution to this problem is very bad! :banghead:
    I'm a fickle (sp) fucker as it is so it wouldn't take a lot for me to sell the CSL on and try something else, seeing as it's not an everyday car for me anymore I hope BMW/Murkett's can cure it when it's in for it's inspection or I'll be CSL'less very soon... I have a very big itch for a Porka or a Ferrari again at the moment! :whistle: :banghead:
      Yep with you on that idea! I love my csl but its been nothing but trouble in 6 months of ownership (alternator,rear springs,viscous fan radio,oil leak,battery, v belt tensioner and pulleys and now the clutch) and am also thinking of moving it on! should have got a gt3.
      p.S and thats at 48k:bigcry:
        wish id kept my gt3!
          I feel quite lucky in my 2 years ownership to have just had an alternator & throttle potentiometer go tits up! Owning a CSL has been a very positive experience for me :thumbs:
            Mine has been great for the year I have owned it.
            Its like any car, just the luck of the drawer.
            Some may have a friday car:whistle:
              if you dont short shift it doesnt slur thus redline and its fine :bigcry:
                Aren't you running a full drenth sequential box on your car Gorilla?? This issue shouldn't trouble you at all :hahaha:
                Anyway ... back on topic
                My take on this is three fold.
                Yes there's a genuine software issue with the system that will clear if you catch it early - but it will eventually come back depending on the type of driving and driving style used.
                Secondly, the mechanical side and this relates to the SAC clutch pack. The interface between this and the software isn't that great and over time the system either over or under-compensates for wear thus the experienced slip or slur.
                Thirdly and this is when the software isn't updated consistently or reset periodically and the eventual clutch plate wears out or the flywheel becomes worn, or another part of the system (such as the release fork, release bearing, plastic sleeve guide) eventually wear out causing the system to 'catch'.
                I have personally NEVER experienced the so called 3rd to 4th gear slur.
                I have however experienced the take off slur and this was quickly corrected with a reset.
                Now to the reset part: I have a suspicion that the dealerships may sometimes not be doing the correct reset on the software. After doing a bit more reading and playing with my Autoenginuity tool, it turns out there's actually 5 different commands that is involved with the SMG clutch.
                First is a soft clutch reset (I suspect this is the same as the drive above 30mile/h, in neutral and pull both paddle back reset) - it reinitialises the system vis-a-vis the wheel speed rotation sensors.
                Second is a Clutch Slip reset (this is by far the most noticeable and effective reset when you are experiencing s slight slur when taking off) - I do this reset on my car regularly and have not experienced another take off slur ever since.
                Third is a clutch curve re-adaptation - this is an interesting one - I tried this on my car the other day and to my surprised it changed the whole dynamic of the way the car shifted and released the clutch. I have to honestly say that this is the MOST NOTICEABLE Reset of them all - whiplash is an understatement with this reset. I was almost a bit concerened that I'd broken my car. But after taking the car for a good moderate drive in different shift speed settings with part and full open throttle shifts I could immediately feel the system "adapting" to the driving style, eventually it became crisp and sharp with no hint of hesitation or clutch slur. I believe this is the full initialisation that the dealership uses when a new clutch pack is installed or a SMG pump is changed.
                The fourth is called the clutch take up point reset - I usually do this in conjunction with the clutch slip reset and it works well and take all of 2 seconds to do. With this reset the clutch pack is simply opened and closed once.
                The fifth and is one that I have not tried is the longitudinal acceleration sensor reset. This is part of the SMG system and on the system it is a Mandatory Reset whenever the SMG pump has been replaced. I have not tried this, so am not sure what it does exactly yet.
                My take on this whole saga.
                Yes there's an issue, but being a widely reported item I do think that owners actively 'look' for it, and we hear it on the net as a result.
                I do believe that the only way around this is:
                1. Buy a tool or buddy up with your indy shop with one and reset your system on a regular basis before anything mechanical is worn;
                2. (and somebody really needs to try this out) - use a Non SAC clutch kit with the exact same clamping pressure as the OEM system and if possible run a single mass flywheel rather than a dual mass one (but not a solid centre clutch, a sprung one if you like your drivetrain components).
                I thought it might be helpful also if we all record our driving styles and see if there's a common denominator, I've deviced the following template:
                When Engine Cold (shift speed): s3
                When Engine at operating temp (shift speed): s4
                Shift speed used at track : s5 or sometimes s4
                Lift on upshift: No
                Lift on downshift: sometimes
                Full throttle redline upshifts periodically: yes
                Part throttle redline upshifts : never
                Launch Control use: never
                Software reset period: usually every two to three weeks
                  how do you do this one out of interest please ?
                    That's a good point. There was a lot of discussion about this 2-3 years ago over on mtorque/bm3w and I think it resulted in pretty much every CSL in the country spending a day at Murketts !
                      very true of must internet issues but clutch slur is not one of them..........its real:thumbs:
                        Heres me in mine.
                        When Engine at operating temp (shift speed): s6
                        Shift speed used at track : NOT YET
                        Lift on upshift: No
                        Software reset period: Not yet.
                          Lift on upshift: No
                          Some great info as usual there mate :smokin::thumbs:
                          Mine seems to 'slip' into 5th & 6th gear, rather than 3rd to 4th Gear, it usually happens at full throttle, I can make it better by slightly lifting when upshifting but seeing as that car should already be doing this for me I would like to keep the throttle nailed!
                          Can you give any more details on the 'Soft Clutch Rest', is it simple as it sounds, go above 30mph, knock the car into neutral and pull both paddles back?
                          Finally to give some further info this is my take on use:
                          When Engine Cold (shift speed): S5
                          When Engine at operating temp (shift speed): S5
                          Shift speed used at track : Not been on track yet
                          Lift on upshift: Sometimes
                          Lift on downshift: Yes, usually
                          Full throttle redline upshifts periodically: No
                          Part throttle redline upshifts : No
                          Launch Control use: Never
                          Software reset period: None whilst in my ownership (3-4 months now)
                            Mine has never had any issues, just follow these steps:
                            always change gear with your foot to the floor - this may sound nuts, but it is very easy. If I want a nice steady drive, I change gear at 1500prm with the throttle at 100%. This makes the computer software register a 100% open throttle gear change and thus the clutch release duration is kept to a minimum (i.e. no slurring) You have to imagine what the computer "thinks" as you ask it to change gear. Just go through your mind how you would drive a manual car. If you want a nice smooth gear change, you release the clutch pedal gently. The CSL software will self learn the way you drive the car - so lifting between gear changes will cause slurring.
                            This is the reason why most people find their cars are brilliant after a thrashing on a trackday, but it tails off in coming months after that.
                            If you only allow the computer software to register 100% open throttle gear changes, it will release the clutch quicker all the time.
                            I have doing this now for nearly 4 years - gear changes are so good I only ever use S4. S6 almost snaps my head off! Most other people who have tried this also report that after a short period the clutch slur goes, provided it wasn't completely buggered before.
                            In most cases of slurring - clutches have been found be well within tollerances. It's the transfer onto the flywheel that does it.
                              Great advice as ever! Does anyone know how much BMW charge for these resets and software upgrades on the box?
