Clutch / Gearbox
    Originally posted by thegingerninja View Post
    Mine has never had any issues, just follow these steps:
    always change gear with your foot to the floor - this may sound nuts, but it is very easy. If I want a nice steady drive, I change gear at 1500prm with the throttle at 100%. This makes the computer software register a 100% open throttle gear change and thus the clutch release duration is kept to a minimum (i.e. no slurring) You have to imagine what the computer "thinks" as you ask it to change gear. Just go through your mind how you would drive a manual car. If you want a nice smooth gear change, you release the clutch pedal gently. The CSL software will self learn the way you drive the car - so lifting between gear changes will cause slurring.
    This is the reason why most people find their cars are brilliant after a thrashing on a trackday, but it tails off in coming months after that.
    If you only allow the computer software to register 100% open throttle gear changes, it will release the clutch quicker all the time.
    I have doing this now for nearly 4 years - gear changes are so good I only ever use S4. S6 almost snaps my head off! Most other people who have tried this also report that after a short period the clutch slur goes, provided it wasn't completely buggered before.
    In most cases of slurring - clutches have been found be well within tollerances. It's the transfer onto the flywheel that does it.
    Another method for me to try, thanks.
      That must be hard to comprehend, so accelerator FLAT to the floor regardless of whether or not your changing gear at 1500rpm or 8000rpm!? :bigcry:
      I've just been out in mine and given it a pasting for around 35 miles, basically changed quick as I could in all gears, varied throttle positions and not a bloody thing, no slur at all and even on occasions flooring it in second to the redline through the gears it really went well, banging into gear and got my pulse racing! :smokin: :supz:
      Originally posted by wazadaza View Post
      Great advice as ever! Does anyone know how much BMW charge for these resets and software upgrades on the box?
      I spoke to Andy at Murkett's yesterday and he advised it was £45 for a software update :thumbs:
        I have just tried this. This morning i went out and from the get go was using 100% foot to the floor shifting on upshifts (bit harsh in the lower gears) . Regardless of revs foot was to the floor.
        Problem solved............................................ ...................................
        for the majority of my outing.
        After the car had warmed up i selected S6 and remained changing at foot to floor. after a while i noticed a slight hesitation at around 5500rpm this was followed by more and more sluggish changes so eased back and changed to i think it was s4, Problem gone again!?!?
        My question is does the software learn different driving styles in different modes?
        I didn't select th s6 mode again as i was nearing home and steadily cooloing calming down for parking up and switching off. Will be experimenting again next time i'm out but for the first part of this drive the car felt sharp, crisp and precise.
        TRY IT.
          Not sure about only changing with 100% throttle openage, even if it is low RPM you've still gotta mash it :hahaha: - would get interesting in the village particularly in traffic in 1st or 2nd :hahaha:
          Someone posted that they drive like that AGES ago on Mtorque/BM3W - Ninja it's not you is it? (Simon?)
            That's what I can't seem to get a grasp off, don't think I'll try it tbh :hahaha:
              Yep - it's me, Elliot.
              I've only ever driven my car this way ever since I owned it. I probably gave a fairly short description of how to drive it like this.
              Obviously you can't change gear at 100% open throttle from 1st to 2nd in traffic. I drive mine in S2 or S3 until it has warmed up. I only use my CSL as a toy now, so I rarely drive in any traffic to be honest.
              I tend to change gear very early in the rev range (1500 rpm) or very late (above 6000 rpm) to stay out of the maximum torque band, as it appears to be the torque that causes the slurring.
              I have said before that it sounds like complete madness to drive like this, but it is surprisingly easy ( not in traffic). Even if I'm just gently cruising down the road at 50 mph following a line of traffic and I want to change from 5th to 6th, I floor the throttle flick the paddle for 6th, as soon as the gear is fully engaged, lift off back to a balanced throttle - you only gain a couple of mph, give it a go. It just sounds odd when you read it here on a forum, but if you get in your car and try it, it's not a problem. You just have to programme yourself to get through the gears quickly - 40 mph in 6th gear isn't a problem. If anyone has really bad slurring, drop into S2 or S3, and perform 100% throttle changes at 1500 rpm, or even 1200 rpm if you can. The lower the revs, the better. Then build it back up to S4, and S5.
              The whole issue of the clutch slur is not a mechanical one in my opinion, the actual cause is down to the software releasing the clutch too slowly. The computer only has 3 variables to take into account when orchestrating a gear change, road speed, throttle position (engine load), and revs. If you only have 10% throttle loading, then the clutch operation is going to be fairly gentle to give a smooth drive - I think this becomes absorbed into the self learning part of the software and manifests into slurring at full throttle, either as slow clutch release or re-loading the engine too soon. My car certainly feels as if there is a definate gap between engaging the gear and reinstating full load. Either way, my car has been mint ever since I drove it like this. If I had any computer skills I would video the way I drive and load it onto youtube....but I haven't the faintest idea - any takers?
                Love you Ginger
                Normally, you just talk Bollocks :thumbs:
                lol
                  Originally posted by TANKSLAPPER View Post
                  Love you Ginger
                  lol
                  :hahaha::hahaha::hahaha:
                    Hi,
                    Not wanting to shoot off on another tangent,
                    but while researching the 'SAC' Clutch I came
                    across this article.
                    Given the design of the DCT clutch system,
                    odds on one clutch, evens on the other, then
                    as explained in the article, there is a downside
                    to it in a performance car.
                    Anyway back on topic, its interesting that companys like
                    Valeo offer 'SAC' replacement clutches which drops
                    the Dual Mass Flywheel for a single mass and then
                    drops the 'SAC' pressure plate for a more normal
                    sprung type finger one.
                    Many 328/528 owners report much better gear changes
                    and clutch feel once the original SAC is replaced with
                    these type conversion kits.
                    I am starting to think along the lines of a Steel
                    single mass flywheel, but not to light so that stall
                    and inertia become issues,retain the E36 M3 Evo pressure
                    plate and the E46 M3 standard disc or maybe a cerametallic
                    one.
                    There is cleary a design flaw to the SAC pressure plate,
                    so although I am reading posts where owners are undertaking
                    different proceedures or driving sequences to make the
                    issues better, I do not believe you can over come flawed
                    component design, longterm, with these type solutions.
                    Still its certainly stoking the debate, as Clutch Slip is an
                    issue on the SMG 11.
                    Regards,
                    The Gorilla.
                      Originally posted by Kev.H View Post
                      how do you do this one out of interest please ?
                      Second is a Clutch Slip reset (this is by far the most noticeable and effective reset when you are experiencing s slight slur when taking off) - I do this reset on my car regularly and have not experienced another take off slur ever since.
                      This is done via a third party tool - mine's made by Autoenginuity from the States. In terms of the SMG component sensors and resets it is dealership level (if not slightly better as it monitors and allows reset of individual components and sensors rather than a generic command that might include a whole host of things).
                      Can you give any more details on the 'Soft Clutch Rest', is it simple as it sounds, go above 30mph, knock the car into neutral and pull both paddles back?
                      Okay, after reading the SMG training manual 3times I've come to the conclusion that the soft reset really has more to do with the DSC system than the SMG to be honest - basically it resets the volatile memory part of the DSC system in correlation to the wheel speed sensors (i.e. if you change wheels sizes ect). This reset is described in the owner's manual - but I can see it as a separate function on the Autoenginuity tool.
                      To an extent yes - Although within the non Volatile memory part of the SMG control unit and the MSS54 DME are pre-determined codes and change patterns that never change - these outline the parameters so whatever changes within the volatile memory will still be within these parameters.
                      That's incorrect I am afraid - it's way more complicated than that (I wish it was that simple, although I imagine if it was it'd drive like complete bonkers). The SMG Control Unit is basically a signal receiver and hydraulic operator - it's the MSS54 DME and the DSC Control unit all together that determines how the gear change is executed via the SMG CAN bus.
                      If you like the MSS54 DME is the brain and the SMG control unit the hands and feet of the system - the CAN bus is the spinal cord.
                      Originally posted by from SMG training manual
                      SMG II Control Unit
                      Communication with the DME is via a dedicated CAN bus (SMG II CAN Bus). Based on
                      instructions received from the DME the SMG II control unit manages the clutch solenoid
                      valve, the selector shaft up and down solenoids, and the selection angle solenoid.
                      While the SMG II control unit receives many of the inputs and manages the control of the
                      hydraulic system, the DME is responsible for and controls all gearshifts. Sensor inputs
                      received by the SMG II control unit are relayed to the DME for processing and monitoring.
                      And these are the signals monitored via the CAN Bus:
                      Engine Speed
                      Engine Coolant Temp
                      Engine Oil Temp
                      Intake Air Temp
                      PWG EDR Feedback Pots
                      Wheel Speed
                      Transverse Acceleration
                      Steering Angle
                      Cruise Status
                      Parking Brake
                      Door Contacts
                      Brake Light Switch
                      Key Memory
                      And I've not even gone into what the input signals are monitored by the SMG control unit and what is communicated with the MSS54 DME ...
                      So way more than just the road speed, throttle position and revs that you speak of.
                      I will come back to this a bit later. Having read the actual SMG training manual 3 times, I actually now have a much better understanding of how the system works.
                        i dont understand any of this but i love reading it :thumbs:
                          +1
                            +2
                            Just happy that mine doesn't slur :thumbs:
                              [QUOTE=glendog74;n392250]+2
                              lol!! :hahaha:
                                +2
                                Yep - the red wheels DO make you gay - you homo..!!! :gayfight:
