BMW Performance Brakesystem
    Originally posted by Levente View Post
    :smt055 where can i buy those in Germany?
    I've no idea mate maybe invest some quality time with GOOGLE.de :thumbs:
      yes but Matt is my CSL Prophet ok anyway thanks for the help :supz: :beer:
        im just eager to replace the whole brakesystem, cant acccept these default brakes. im fanatic you guys should know it by now XDDD :hahaha:
        If you’re looking for a top quality high performance brake system then please consider the Performance Friction Kits.
        Our 355mm dimpled front disc kit (3100.0004) uses Forged Monobloc Calipers providing a very stiff platform for the braking components as opposed to the 2-peice AP products.
        They also use 4 pads per calliper providing double the leading edges for extra bite and a much more even pressure distribution, reducing distortion in the disc and restricting pad tampering and drag also improving thermal stability. All this results in a much more consistent pedal feel and longer life for the discs and pads.
        Our kits also of course come with PF Molybdenum Alloy 2-Pice Disc assemblies.
        The ZR31 Caliper used is a race quality component but comes with rubber boots for low maintenance on road use.
        And you can even choose your caliper colour.
        This kit is a bit more expensive than the AP but you are getting a lot for your money and you will even be saving on replacement parts in the long run.
        A 1:1 scale drawing to check clearence can be found here - http://freepdfhosting.com/b9463cb3a8.pdf
        Calipers and discs look like this-
        Get in touch if you would like any more information,
        Charlie
        [email protected]
        +44 (0) 1295 221 023
          They look thought through and they kind of sit between the AP's and more expensive CSL Cup / Alcons. Would be useful to include the price and what discount CSL owners get :whistle:
          My only critque would be the amount of support for that type of quad pad configuration.
          Kindest,
          Jonathan
