How has Nitron solved the knocking in the rear problem...I have the same knocking but last time I talked to them Ben said it was all ok...just what they sounded like!.......Must say fucking good suspension though! And I ve been through Bilstein PSS10, KWv3, Intrax, standard M3 and CSL.....Nitron by ftw
Thank You Spires and Nitron
What kit you running O'Neill?Originally posted by O'Neill View Post80N/m front and progressive rear 45-82-110N/m standard mounting position.
No issues with the original setup other than the rear knocking, just wanted to try higher spring rates and whilst doing that went with the rear coilover.
I had a similar problem with my old Nitrons knocking at the rear, it's when you try and lower the car too much they knock.
No problems since i've changed to the rear coilovers too, car is so much better, I think I'm running the same spring rates as you.
How do you find the ride now?
Excellent O'Neil - keep us posted on how you get on with new set up.
I find this how knocking issue strange. Was this even on track or only on road (i.e. pot holes etc)?
What rubbers did you guys run on the separate springs? Did you run the OEM 5mm spring pad on bottom of spring (found at top on OEM CSL set up) and Nitron's 2mm rubber pad on top of height adjuster?
