Well I've tried the bonnet switch again, and put the main headlights on and they work fine with no dimming, so does that suggest it's not a battery issue? Also I have checked and the battery is only a couple of years old.
The gears are changing fine, I can hear the clunk. When I turn the key in the ignition I can hear a pump whirring for a bit, not sure which one it is.
Read about a "dead spot" on the starter motor, tried rocking it but nothing.
Could it be a failed starter motor?
Any ideas what the significance of the warning light is? I think it is the emissions warning light, which stays on in yellow.
Also, just had a thought, is it normal with CSLs to have a delay between turning the key and firing up? It has always waited for a second or 2 before doing anything. Didn't think anything of this but wonder if it was a symptom if this is not normal?
Sorry to keep with the questions!!
That was bad timing in September,you knew we were going,couldn't you have waited untill October,Shimmy has put a lot of time and effort into this trip.:whistle::whistle:
