K** csl
  • Mark CSL
    Moved this here better than on the open fourm :thumbs:
  • Matt21
    Originally posted by jupe777 View Post
    See a UFO at Elms today , All looked good Matt.
    Thanks! Currently awaiting a decision from me on whether they strip the gearbox to investigate the clutch slur.
  • jupe777
    Originally posted by Matt21 View Post
    If you happen to pop by make sure they are treating mine well!
  • jupe777
    Originally posted by GregorFuk View Post
    Hmm, could the oil cooler have been the issue all along? Wonder if it was blocked and restricting flow preventing proper oiling of the cam lobes. Seems very odd that two separate engines have gone in the same way when installed in the same car. Suggest like it might be an issue with an external system.
    Yes I have been having that conversation with Elms. Regarding the followers, Elms were changing them as well.
  • Mark CSL
    Yip sounds like it could have been not sure if they cleaned all the parts after the first engine went it could have contaminated the oil pipes and cooler :whistle:
  • GregorFuk
  • jupe777
    Popping in next Tuesday, will keep an eye out for yours. What are you having done Matt?
  • Matt21
  • jupe777
    Ps it needed a new oil cooler too.
  • jupe777
    Thats what happend the first time :whistle:
    GET THE FOLLOWERS CHECKED you can see the weare on them
    Thanks Mark, I shall give Bill @ Elms a ring tomorrow tomorrow to discuss. If you have any other relevant info pls let me know. Thanks Jim
  • Mark CSL
    Tappety noise, on investigation no.6 cam showing some wear and flat spot on rocker arm. Bit sad considering engine only done 8k. Someone has been waiting 12 months for a cam and I was told they should be another 3 but still waiting for confirmation. Elms are stripping the top end down and I will lock the car away in my garage for as long as it takes. Heyho.
  • jupe777
    Thought I recognised it as yours. Not had much luck this year
    What were the symptoms?
    They told me no BMW supply and original manufacturer may have to retool :banghead:
  • Matt21
    It's mine, cam shaft issue. Could be out of action for a while :-(
  • jupe777
    That was the plate. Who has the car now?
  • Matt21
