YOU DONT GET IF YOU DONT ASK
shimmy :thumbs:
Cluch Slip / Slurry on the up changes
how many miles
my new clutch has done around 25k miles but of that about 3-4k track miles
shall i give it a go before warranty runs out in January!
yes because at that point it is warn out, but it wont be unless its done high miles, the clutches on these car last wellOriginally posted by Jaw_F430 View PostSo new they are 2.0mm from new and it needs to be 1.1mm or above for them to replace it?
If it is below 1.1mm then will they try and charge you for it?:smt017
It worked for me too, a couple of years ago, thanks to Mark :beer: you probably dont remember but we spoke on the phone at the time, after i had posted on MtorqueOriginally posted by mark cslOk lads here is what to do.
Go in to bmw if under warranty:thumbs:
Tell them the problem and ask them to fix it they will ask you to autherise them to take the clutch out about 3 hours if the clutch is above 1.1mm then its good and they will replace it free under warranty.
My CSL had done 52000 miles and was not under 1.1mm they come with 2.0mm new i got a new clutch and flywheel as it was blue with the slip
The clutch adaptor cant take all the little changes up thats when you get clutch slip / slurry.
I know of about 8 cars that have done this and all get new clutch and flywheel under warranty
Problem solved :thumbs:
Problem solved :thumbs:Tags: None
