How to change a CSL steering wheel Video
ThanksOriginally posted by davidcool, I like it with your scotish accent.... :thumbs:
that remember's me back in 76->80 when I was a kid living in Peterhead and later in Aberdeen.... damm, it's so fare.... and what good time I had as a kid in scotland.. :bigcry:
i live in the middle of glasgow and edinburgh
So i get a bit of both cultures :hahaha:
Polite Edinburgh and Ned Glasow :hahaha:
I might just add to this DIY if you don't mind Mark.
1. Disconnect the battery before you remove the airbag (no chance of the airbag warning light coming on) - if you don't disconnect the battery make sure you DON"T TURN ON THE IGNITION OR ANYTHING ELECTRICAL whilst the airbag is disconnected.
2. The Torque spec for the steering wheel bolt is 62.5Nm or 46ft-lb - best to torque this up to spec if you have a torque wrench.
3. Becareful when you pull the steering wheel off, sometimes the clock spring (the black plastic thing behind the steering wheel) can fall off ... if it falls off it's a pain in the ass to wind back together (usually requires buying a new clock spring from the dealer (very expensive).
4. To release the airbag you have to poke the screw driver on both sides of the steering wheel (I find 2'OClock position pointing about 20 degrees downwards is the best angle to release the spring clip).
Will be looking at doing this at the weekend Mark, cheers for that.
Any recommendations on changing the plastics facia and paddles over? I can do the paddles no bother I am sure, just the plastics I am worried about. Don't want to mark them, I'm sure they are easy enough though.
Cheers in advance,
Baz
Trying to get the airbag out to fix my flappy paddles .. but just cant seem to find the springs with the screwdriver...
Seem to have the screwdrivers behind the airbag as it comes forward a little when I lever it a bit.. but obv that's not the way to get it out!
Have read these threads..
I have been trying to remove my airbag as the fascia (lower) needs replacing................... Anyway im turning the wheel and pressing two screw drivers throught the holes & the fooker just wont come........and i am really trying, any harder and something will break:bigcry: Am i doing it right or is there some trick
Steering wheel removal! Great Video! Jus trying to remove my wheel now, but cant undo the springs for the airbag? Tried a few different screw drivers with no joy? cheers si
and also saw this on youtube, looks like the same arrangement?
Looks easy but I just don't have the knack!
From reading the threads and looking at the vids I should be:
- coming in from 2 o'clock position with a flathead screwdriver
- blade of the screwdriver horizontal
- pointing it slightly at the dash
Any more tips pls?!
Or any airbag popping experts in Southampton, Basingstoke, Portsmouth area-ish mind me popping by for your expertise, will buy you a beer!
Chs, Dan
:banghead:
Angle back with your screwdriver as if you angle forward it misses:thumbs:Originally posted by danp View PostTrying to get the airbag out to fix my flappy paddles .. but just cant seem to find the springs with the screwdriver...
Any more tips pls?!
Chs, Dan
:banghead:
YesOriginally posted by thegingerninja View PostThis link doesn't work anymore? I have seen a similar vid on YouTube, but not for a csl. Having looked behind my steering wheel for the 2 holes to push the screwdriver in - I have 2 indentations but the "holes" are not there. Do I push through the rubber to make the holes myself?
