How to change rear plate light?
    Anyone had to change a rear number plate light. How do you get to it?:banghead::banghead:
    Sorted. :thumbs:
      Good stuff mate, you have to quite brutal with it. There's instructions in the handbook for it too, just for anyone else.
      I changed mine for wee LED jobs, pretty funky and cheap enough.
      http://cgi.ebay.co.uk/LED-REAR-NUMBE...634.m333.l1262
      Straight swap.
      Only thing was, I ordered resistors to go with them (couple of quid for 100) as apparently they can throw up an 'Bulb out' warning on the dash.
      I changed mine without the resistors and no warning, so I didn't bother with them. However, as they need VERY, VERY little current to work they glow for a wee while after you've switched them off. Maybe 20 mins or so. Lighting up your rear plate just a tiny little bit for that time.
      Freshens up the rear a wee bit, for a fiver what can you say? Then again, if you score the boot with the screwdriver you're using to removed the casings in the 1st place it could prove a costly little mod.
        Straight swap.
        I had to check the bulb type as Ive just ordered some of those xenon LEDs after seeing my mates E92 M3 with bright white xenon as standard on an alpine white. Looks clean and crisp. Cheap mod, cant go wrong, unless like you say you screwdriver the boot. I did manage to screwdriver the thumb thou. :bigcry:
          Aye, my Dad has an E92 330d in White, and it has the wee LED's to light up the number plate. As you say, nice and crisp. I do worry about how much easier it is to read my number plate now though...not good in certain circumstances.
            Yeah it certainly isn't :banghead:
              Why do you guys make it so compilcated?:banghead:
              Just take the OEM from E92/93, a adapter-cable and its done.
              Just did it a week ago.
                'cause that would have been too easy mate.
                Seriously though, was it that easy! doh! I had posted the question up on a couple of other board but had nowhere near as simple an answer as that, never mind. People were talking about soldering resistors inline and hea shrink etc, there you go.
                Cheers,
                Baz
                  surely its easier to just change the bulb than to rewire the car.
                    anyway, if you call it "rewire the car", i call it adapter-cable.
                      Here's my DIY for replacing the regular CSL license plate lights used on the bootlids with the latest OEM LED license plate lighting that comes on the new e60/e90/e92 models.
                      Fortunately for us CSL owners, we are not subject to any bulb-out errors on the dash, so this is a true plug-n-play option.
                      Parts needed:
                      2 BMW LED registration lights (# 63 26 7 193 293) £7 /each
                      2 BMW Universal Socket aka plug connector (# 61 13 6 925 634) £1.00 each
                      4 BMW Bushing Contacts aka pin contacts (# 61 13 1 383 776) if you want to build your own wire.30.28 each. I bought 10 as you can see from the pic below.
                      some 20 or 22 guage wire
                      heat shrink
                      4 Bushing Contacs with wire (# 61 13 0 005 197) £1.00 each
                      Pic of parts needed.
                      [IMG]file:///C:/Users/Mark/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
                      Finished pic. They look really clean:
                      I have them orderd for tomorrow i shall post pix tomorrow :thumbs:
                        Aye, it does freshen the back end up a bit. I 'might' replace my ones with the ones above too, so that they actually go off when I switch the lights off. Instead, they glow very, very dimly. Then again, prob won't bother as it takes very little current anyway.
                        Nice post though Mark, a very cheap mod and not having the bulb warning light coming on is a bonus for us CSL owners! :-)
                          I fitted mine last week or so and glows the same after turning off. No bulbs sign thou on dash. They do look a little too blue so hoping to go E92 OEM set up too. Where can you order from, BMW stealers?
                            Yip BMW
                              Might rob my e90 later...
