I find the setup with Pagid RS5/DS2500 front/rear or RS29 front/ DS 2500 rear excellent, the DS3000 are too agressive for the rotor and they melt fast and get rotten in a year with a few good trackdays...
AP Racing vs. Brembo monoblock
with my extensive testing (sort of) i find that RS14 front and DS2500 rears are the best road/track pad combination
if only track being done then Rs29 or PF01 may beat the Rs14 due to longer lasting and squeaking not relevant
i agree that you should avoid using DS2500 on the FRONT on track days due to pad deposits and avoid using Ds3000 all together due to corrosive effect on rims
That's exactly it.Originally posted by shimmy View Posti agree that you should avoid using DS2500 on the FRONT on track days due to pad deposits
The DS2500s practically melted themselves onto the discs under use at the 'Ring. And before people start saying I was braking too hard, perhaps, but Glendog can attest we weren't hanging around.
I'm now having to clean the pad deposits slowly off the discs :banghead::banghead::banghead:
The DS2500s are ok for road use, but they are definitely NOT up to the task of repeated full force braking on track when 'going for it'.
No such problems at all with the RS29s which are a proper race spec pad.
Appreciate the feedback will take it into account when it's upgrade time :thumbs:Originally posted by Ade View PostThat's exactly it.
:whistle: :whistle: :whistle:Originally posted by Ade View PostGlendog can attest we weren't hanging around.
Agree with all comments about DS2500 - fine for road but pushed to their limits during hard track use.
I use RS29's all-round at the moment coz my car has been a bit of a track whore of late... :hahaha:
Well i am a tight scot and the EBC redstuff do fine and not a lot of brake dust
i am trying the yellow pads this sat at knockhill i shall see if they are better
than the red pads :thumbs: full set costs £122.00 Bargin
The DS2500 i had on were not worth the money :banghead:
I have a set of the 3000 but not used them yet :whistle:
The 380mm brembo discs weight is 9.5kgs and not 10+.Originally posted by B0rJarZz M. View Posti have both kits.
Alcon weights 3.7kg each caliper (horror)
AP CP5555 weights 2.9kg (Painted)
AP cheaper than Brembo and Alcon and a lot of less unsprung weight.
The M3 E46 don't need more than 355mm anyways...
Also i got 380mm brembo discs and weights 10.XXkg each.
What is the weight of the AP racing caliper with the pads ?
My brembo monoblocs with pads are 5.2 and I am pretty sure they are lighter than the AP racing with pads.
See here -> https://nam3forum.com/forums/forum/c...8899-my-m3-csl
