mine checked by bmw with no prob.....so i choose the oil cooler first:thumbs:
the size from vac is 11'x11' (27cm x 27 cm = 729 cm²), to have the same cooling area from mocal (think automotive), it must be the 23,5 cm x 34 cm (44 row)= 799 cm², isn't it too big ??:smt017
but it think oil cooler and new water rad is a good first effort to solve the problem
my water rad looks like it has ben trough the gulf war on the front! could easily be reduced performance tbh
This is a big factor. The amount of insects and general s**t stuck in the fins of the rad, air con rad, oil cooler will have an effect. A rad removal and good clean will help.
Do any of you techinical gurus know if the engine temp (rising to red on track after 4-5 laps) and throttle irregularity (at various points) could e caused or linked by something (sensor)
I had throttle sensor changed after Spa limp mode, and exhasut sensor changed more recently?
Thats funny because i had my exhaust temp sensor replaced today at bmw and whilst on my way home i noticed the coolant level moving towards 2/3 area whilst in slow moving traffic, its not done that since i had viscous fan change
So after reading many posts on this it seems to result in the following;
The guys who have witnessed high (and i mean towrds red line) water temps ON TRACK after 4-5 laps ususally in warm weather, have chased down various water cooling faults but never managed to fix. People have changed stat, pump, rads, sensors but seems no joy.
So let us presume for a minute that water temp highs are a symptom and not a cause of the problem!
I have found a few poeple post that they have solved the issue by replacing coils. injectors or sensors that are cusing they presume hig cylinder temps probably due to running lean due to these faulty bits. Thorney also has said on another forum that degrading coils or injectors could cause the high temps on track.
