thoughts about track rims and tyres
    I have heard bad things about them for track use? Basically copies of other peoples wheels and not very strong? Only what I'd read, they appeared on my radar when I was looking.
      Gorilla
      Id also hard that the Rota wheels were soem of the better replicas but still not sure id trust them on track even if i dont push minethat hard....... I can see why Nathan might not wnat them as they dont like the extra weight apparently
      In the states alot of the guys use Apex ARC-8 rims, similar to Pro Race 1.3 i think
        git
          Hi,
          The Guy with the E36 GTR ran them for
          about 9 months before he sold the Car.
          He used to Race in Endurance Races ,
          and ran a set of these wheels with full slicks
          on his E36 GTR Track Car with no issues
          that I am aware of.
          He was no slouch in that Car either.
          Regards,
          The Gorilla.
            Gorilla
            A lot of he evo lads run rotas, on big power track cars, I had a set on one my evo's, i did not track that one but they stood up to road abuse with no issues.
            Gorilla, any idea what they weigh?????
              rotashop.co.uk is the home of Rota alloy wheels with a great range of stock and next working day delivery. Full range of alloy wheels on the site now with highly-trained enthusiastic staff. Get 10% off the complete alloy wheel range today with lowest prices guaranteed! Buy online today! 0% Finance available with Klarna
              thye have a big selection of replicas
              Rota drift weigh 9.5kg each, £850 for 4 18x9.5 approx
                http://www.rotashop.co.uk/?gclid=CML...FWlr4wodTwhVMA
                I might be guineau pig
                  check out this uk site
                  only trouble might be et20 only for 18x9.5J E46 versions
                    http://www.rarerims.co.uk/alloys_sub...=22&RangeID=77
                    What reason do you see the et20 being a problem shimmy?
                      well my calcs (bear in mind i am new to this stuff) show that my rear CSL rim 19x9.5 et27 if put on the front will foul the arch if a camber of say -3 is not used
                      Now if you bring the et down to 20, thats 7mm further out which means it will foul even worse unless a -3+ camber is used, god knows how much
                      but saying that Nathan is using et14 but i guess he will run a massive camber for race circa -4/5 anyway
                      :smokin:
                        Hi,
                        Shimmy- just my quick calcs before I dash out.
                        Some guys run the rear CSL rims on the
                        fronts which are 9.5 J ET 25 if I remember.
                        So at ET 20 your 5mm more ET would push the
                        rim out about 2/3mm more.
                        At around 3.5 to 4 degrees camber an
                        an ET 20 9.5 J rim might need the standard
                        front arch lips well rolled, but it should
                        go.
                        The gain in extra O/A track width on the front
                        will also help turn in but the trade off, and there
                        always is, that front tyre scrub radius will increase.
                        Regards,
                        The Gorilla.
                          Originally posted by The Gorilla View Post
                          Hi,
                          go.
                          Regards,
                          The Gorilla.
                          Gorilla
                          Thanks but it is def worse than that as OEM rears are et27 (fronts et45). The difference between et20 and et27 is a straight 7mm as the face of the wheel hub is moving 7mm one way. Therefore the ROTA rears on the front will foul the arch by 7mm more than OEM rears, so i am not sure if they will fit without rolling arhces or even with:whistle:
                            Hi,
                            Shimmy- I can see what your saying
                            but I was working on the basis that
                            the standard CSL fronts at the tyres-
                            235 35 19 and pending on which make of tyre
                            are O/A Diam of 647mm.
                            265 35 18 and again pending on which make of tyre,
                            Diam of 642.7mm.
                            Even allowing for the increase in the ET
                            the O/A diam is almost 5mm less, so
                            rolling the arch should make it work ?
                            While on this subject has anybody ever run
                            17s with say a 40 profile side wall and then
                            firmed the suspension right up tight for track
                            work ?
                            A 265 40 17 comes in at 643.8 mm so O/A
                            Diam is good, and increased side wall profile
                            gives a little 'suspension' via the tyre to compensate
                            for the harder damper setting, and I think a car would
                            ride much better in the corners due to the tyre side
                            wall compensating and assisting for the progressive roll in and
                            then out again for good cornering, while being a bit stiffer
                            for the straights.
                            This is very much akin to current F1 suspension.
                            Although 30/25 and even 20 profile tyres might
                            look the dogs, any surface change is more or
                            less transmitted straight to the suspension as the
                            the tyre side wall has such a small margin
                            from which it is able to absorb.
                            Also explains in part why the majority of 18'' slicks
                            go 650 upwards.
                            Porsche are 650 fronts and 670 rears I think,
                            and they handle OK ishhhhh.
                            I ran 230 625 18 slicks once on a
                            e30 m3 and it was bloody awful.
                            Always looking at the inner wheel beading
                            and the way the tyre is located to the rim
                            for Track Wheels, as if the tyre starts rotating
                            on the rim, which can and does occur it will
                            cause untold issues.
                            Regards,
                            The Gorilla.
                              17s won't fit over the brakes will they?
                                def not over APs,
                                not sure about stock brakes but you wouldnt want to be on track with those anyway :smokin:
