Extensive Engine Modifications
    Just thought this might be of interest to someone;
    A guy in Greece has a E46 M3 with extensive engine mods and still running N/A configuration:
    350whp whats that about 390hp? Interesting thing is that its higher than what E92 M3's are putting down
    Quoting ""
    ACCRALITE 12,5 : 1 pistons ( "shaved" block to go to 12,65 )
    arrow pressision connecting rods
    arp head studs
    arp connecting rods studs
    arp main studs
    Oversized One Piece High Performance Stainless Steel Valves
    Balanced and Blueprinted Valves
    Balanced Springs
    Resurfaced Face
    Titanium Valve Spring Retainers
    VAC High Performance Valve Springs
    lightweight & balanced crank
    OEM CSL carbon intake
    ecu reprogramed / aplhaN management ( oem csl dme )
    schrik cams 304/296 12,5mm lift
    diamond coated cam followers
    8.500 rpm limiter
    Bosch larger fuel injectors ( 15% more fuel )
    rogue power pulleys
    custom headers
    custom section 1 decat
    custom Xpipe unresonated
    eisenmann race muffler / one tip mufler
    the last dyno run was 347 rear wheel power...it was with 290-282 cams...
    on a rototest dyno that measure power to the wheel hub...
    now the new dyno was done in a mustang dyno ( which here were i live is considered the most strict dyno that we have..many cars from tuners are let down in that room...., the E92 was at 325-330rwp in there... ) and from what the owner told me it reads about 10% lower than the one i was using all these years....
    so the new dyno was 340 at the wheels....
    im going back for some more test runs cause the clutch let us down in the progress of the dyno session...
    no dyno plot from the 340 but i am going to get one the next time i am going in a couple of weeks...
    Nick
    Nick's a member on this forum ... his car is pretty well known.
    i know i know its not a CSL but is my baby which i love and spend a fortune on it....:banghead::smt055 specs accralite 12,5 : 1 pistons arrow pressision connecting rods arp head studs arp connecting rods studs arp main studs Extreme Port and Polish Work Titanium Valve Spring Retainers VAC High Performance Valve Springs
    However you really can't compare numbers from a hub dyno to a rolling road - they'll read completely different - you can't even really compare dynos to dynos or dyno runs done on different days with different ambient temp, humidity ect
      What is not known is for how long this engine was working.
      I reckon the ratio is about 11 months in the garage, 1 month in the road.
      It's not very reliable.
        A lot of effort to go to for a road car IMO. 3.4 has to be easier?
          Hi,
          Why mess around with a 3.4 ?
          Go give KK around 30k and have a 3.7.
          Regards,
          The Gorilla.
            cause a 3.4 doesn't cost 30k
            3.7 sounds good though, got any more info?
              Hi,
              These Guys know their BMW stuff.
              Rennsport Kompetenz seit über 30 Jahren Aus einer privaten Leidenschaft zweier Rallye-Fahrer in den 1990er Jahren ist im Laufe der Jahrzehnte ein namhaftes Unternehmen entstanden. Neben einer klassischen typenoffenen Kfz-Meisterwerkstatt werden ebenfalls sämtliche Dienstleistungen aus dem Rennsport bedient. Komplette Fahrzeuge werden von A-Z konzeptioniert, entwickelt und gefertigt. Ein gut ausgeprägtes Netzwerk an
              Owned and run by Sven Kruger, who
              races an E30 M3 with 400 BHP
              from a S14 4 pot.
              3.7 CSL- http://www.kk-automobile.de/html/gal05.html
              Regards,
              The Gorilla.
                Originally posted by The Gorilla View Post
                Hi,
                www.KK-Automobile.de
                from a S14 4 pot.
                Regards,
                The Gorilla.
                Interesting! Any more detail info on specs? They're not giving up much there! Wouldn't want to do it myself, just curious.
                  Hi,
                  AlexGTT- KK spent a lot of time developing the
                  3.4 stroker kit for the S54 and the 3.7 is
                  an evolution of the original 3.4.
                  They are always very tight lipped about
                  their specs.
                  I have driven a 3.4 version and it was
                  very quick, but more suited to road
                  use rather than on the Track.
                  If you dig around on their site their
                  is a little more info.
                  Regards,
                  The Gorilla.
