Just thought this might be of interest to someone;
A guy in Greece has a E46 M3 with extensive engine mods and still running N/A configuration:
350whp whats that about 390hp? Interesting thing is that its higher than what E92 M3's are putting down
Quoting ""
ACCRALITE 12,5 : 1 pistons ( "shaved" block to go to 12,65 )
arrow pressision connecting rods
arp head studs
arp connecting rods studs
arp main studs
Oversized One Piece High Performance Stainless Steel Valves
Balanced and Blueprinted Valves
Balanced Springs
Resurfaced Face
Titanium Valve Spring Retainers
VAC High Performance Valve Springs
lightweight & balanced crank
OEM CSL carbon intake
ecu reprogramed / aplhaN management ( oem csl dme )
schrik cams 304/296 12,5mm lift
diamond coated cam followers
8.500 rpm limiter
Bosch larger fuel injectors ( 15% more fuel )
rogue power pulleys
custom headers
custom section 1 decat
custom Xpipe unresonated
eisenmann race muffler / one tip mufler
the last dyno run was 347 rear wheel power...it was with 290-282 cams...
on a rototest dyno that measure power to the wheel hub...
now the new dyno was done in a mustang dyno ( which here were i live is considered the most strict dyno that we have..many cars from tuners are let down in that room....
, the E92 was at 325-330rwp in there... ) and from what the owner told me it reads about 10% lower than the one i was using all these years....
so the new dyno was 340 at the wheels....
im going back for some more test runs cause the clutch let us down in the progress of the dyno session...
no dyno plot from the 340 but i am going to get one the next time i am going in a couple of weeks...
Nick
Quoting ""
arp head studs
arp main studs
Balanced Springs
Resurfaced Face
8.500 rpm limiter
rogue power pulleys
custom headers
, the E92 was at 325-330rwp in there... ) and from what the owner told me it reads about 10% lower than the one i was using all these years....so the new dyno was 340 at the wheels....
Nick
