what are the best brakes to upgrade to?
    This is incorrect if you do the math.
    The Alcon is the only aftermarket brake kit out there that I know of that more or less retains the CSL brake bias out of the box. I did the math and it adds up.
    See below.
    Standard setup with an equivalent brake pad compound as the front Alcons. I am running pagid rs29 on the front alcons and performance friction pfc01 and the brake balance is "perfect" (quote from a veteran champion professional racing driver and acredited bmw driver training instructor who took my car for a test run around a new track yesterday and provided me with some setup feedback)
    If you want me to get really technical I can ... but as a reference.
    The stock E46 M3 has a front to rear brake bias ratio of 1.98 (i.e. front heavy)
    The standard CSL has a front to rear brake bias ratio of 1.73 (i.e. shifted slightly to the rear compared to the stock M3)
    The standard Alcon kit in both front and rear configuration has a front to rear brake bias ratio of 1.78 (i.e very close to the stock CSL setup)
    Running just the front Alcon kit and retaining the stock CSL rear setup gives a front to rear brake bias ratio of 1.82 (so in between the stock M3 and CSL setup - which I've found to be much much better).
    As for those going with the AP racing kit - those kit are actually WAY MORE rear biased compared to all the other kits out there. For e.g. the 5570 kit has a front to rear brake bias ratio of 1.61 (very rearward biased).
    thank you very informative
      Nathan
      That didnt help at all :hahaha:
      :hahaha::hahaha:
        See below.
        I appreciate your input Tom, but math aside, when I fitted the Alcons, driving the same track, same weather, same wheels/tyres,same suspension.
        It affected the balance of the car under extreme braking, not alarmingly so, but enough for me to notice, and enough to see drops in corner entry/mid corner/corner exit speeds, which also slowed down my straight line speed.
        The alcon kit is very very good, but just makes the car feel unbalanced at 100% attack.
        I am also not the only person to notice this.
        The "issue" obviously has not bothered me at all as I now have Alcon fitted on my Evo X.
        A shameless Matt moment:gayfight:
          Attachment omitted from migration
          You WHORE! :hahaha:
            cheap as chips those itchy mingy alcons :beer:
              Originally posted by Curly View Post
              Glad i bought the gayman now:hahaha:
              Goes with the bag :whistle:
                Originally posted by _Nathan_ View Post
                Can you show your calculations please.
                Just for you mate :beer:
                I used stoptech's formula from here:
                http://www.stoptech.com/tech_info/fo...g_dynamics.pdf
                Torque created by the caliper on the rotor (at the wheel) = TW
                TW = PS x AP x μ x 2 x RE
                PS = Pressure of system;
                AP = Total Area of pistons in one half of caliper (one side of opposed type or active (piston) side of sliding or floater type);
                μ (CoF) = Friction Coefficient; x 2, since there are two sides of the rotor that the pads are exerting force against;
                RE = Effective Radius of clamping force
                RE is expressed as Re = (D+d)/4
                where D is disc usable outside diameter and d is disc usable inside diameter. Although Stoptech provided that the effective radius on the M3 can be expressed as ((disc diameter/20)-(AP))
                The Brake Bias ratio is simply TW (front)/TW (Rear)
                Have fun :clown:
                And for those really good at Physics, here's a really good page full of formulas:
                  My head hurts again Tom - make it stop! :banghead:
                    Have fun :clown:
                    http://www.engineeringinspiration.co...calcs.html#der
                    +1
                      I suggest less of this :banghead: and more of that :smt056 ...
                        Sorry :blalalala:
                        Shane I get what you are saying exactly. When I run different brake pad compounds in my car I notice a shift in brake balance. I can imagine what it must be like with the rear kit also in place.
                        Perhaps time we all invest in a brake bias adjuster :supz::supz:
                          I have just bought this pedal box.
                          :smt055
                            Ps, Ta for the calcs.
                              :smt055
                              Nice box Nath :hahaha:
                                :smt055
                                i can imagine you sitting there watch telly with your feet resting on it:whistle:
