Front Propshaft Coupling?
    What does it look like, where does it go, and how much to change.
    What else should I do when down there
    Thank you.
    Thank you.
    See Gareth or Ant, easy
      Thank you.
      Like this:
      The part should be about £45 but the labour might be a tad more expensive :thumbs:
        Where it fits in the scheme of things:
          You also need a strip of butyle tape because you need to lower the centre bearing to get the doughnut off.if you don't you may get vibration like i did had to buy the tape to mount centre bearing all was good after.i can fit it if you want it done local
            Shimmy I replaced my prop coupling and centre bearing myself. I used a Lemforder part from euro car parts. The car drives loads better from stand still. Must have been flexing. BMW quoted me £600 to replace just the coupler. I did that and the centre bearing for just over £100 .
              :beer:
                They are not that hard to do, and a common wear item unfortunately.
                Why do you think yours needs replacing?
                  Sorry, no PM yet aout when you are popping round to do mine :beer:
                  The Grand PooBaa Giraffe of Elms says its fooked :whistle:
                    Get your spanners and lump hammer out only takes errrr 8 hours
                    Im busy with vanos rebuild and head gasket. :banghead:
                    :thumbs:
                      well here is the old one with 3 big splits ...
