Correct me if I'm wrong. In BMW vanos related part of service 2 , do they just replace tiny £7 filter if required, not exactly in depths:whistle:
Vanos Noise
Thanks shimmy.Originally posted by shimmy View PostI had my vanos upgraded by Raikku and he did the timing and it seems to be much more responsive and def quieter top end.
I'll post up description later
They do nothing to the vanos neither inspection I or II.Originally posted by Chad View PostCorrect me if I'm wrong. In BMW vanos related part of service 2 , do they just replace tiny £7 filter if required, not exactly in depths:whistle:
I think Monkey@chandlers said he cleans it out, but it's not part of the normal schedule.Originally posted by Chad View PostJust thought I'd read somewhere on inspection 2 they did change or just clean the vanos filter, " point being" they don't do an awful lot for the cost of inspection 2,
Vanos filter is easy to change, I do it on every oil change. BMW Watford sell kits with the required filter and o-rings on ebay.
http://www.ebay.co.uk/itm/-/172319659094
As a matter of Interest , what presure does the vanon pump generate,in order to advance/ retard cams, I get pump is driven by the camshaft, and advances through use of solinoids, has acumulator vessel etc, so good seals will play a big part, but ultimately it's the pressure that does the job, can this pressure be checked ?Originally posted by shimmy View PostI had my vanos upgraded by Raikku and he did the timing and it seems to be much more responsive and def quieter top end.
Sorry read that and all i hear is blah.blah.blah.blah blah.....im not technically minded:whistle:Originally posted by Chad View PostAs a matter of Interest , what presure does the vanon pump generate,in order to advance/ retard cams, I get pump is driven by the camshaft, and advances through use of solinoids, has acumulator vessel etc, so good seals will play a big part, but ultimately it's the pressure that does the job, can this pressure be checked ?
Around 115bar as far as i know. Never checked it myself, so can't say for sure. You can check it with inpa/dis.Originally posted by Chad View PostAs a matter of Interest , what presure does the vanon pump generate,in order to advance/ retard cams, I get pump is driven by the camshaft, and advances through use of solinoids, has acumulator vessel etc, so good seals will play a big part, but ultimately it's the pressure that does the job, can this pressure be checked ?
