Originally posted by 83SY
View Post
Donington 31st August with Opentrack.
You def have mor than that to gain!Originally posted by 83SY View PostDownloaded my five best laps and picking the best sector times from each gave me a best lap of 1.18.14 :drool: (in theory)
Target for next time is to break that 1.18 mark. Do think a wider line into Redgate would improve (thanks Shim) one of my laps I did & carried 3kph more through the corner.
artyman:
I've done a max/min corner and straight speed comparison between our best laps and it's very interesting.
If you have a VBox or PBox could do a better comparison:banghead:
Yeah I'll buy it and give it a try. BUT does anyone know a good mount for the rear view mirror. Do any of you use the ultra clamp or can recommend one for a normal camera and I'll get the iPhone attachment.Originally posted by 83SY View PostLooks good Bill. Are you gunna give it a try?
That's the beauty of having your system! Hours of fun when you get home! :supz:Originally posted by shimmy View PostYou def have mor than that to gain!
31psi hot, when checking after a cool down lap.Originally posted by 83SY View PostWill find out and let you know. Think 120 all round but I'm not 100%
What tyre pressures were you running?
When I checked them yesterday morning ( didn't pump them up after td ) 23psi front left the rest 24psi cold.
WAAAAAAAAAAAAAAAAOriginally posted by O'Neill View PostSame as you have in your garage.
Going to Intrax, if you can't beat them join them:hahaha:
Don't think they make that much difference Barry, just more seat time. Don't forget only over a year ago you had a big off and I'm sure it would affect me a little
We tend to drop pressures to keep them 31-32 all round BUT tbh what you really need to do is check pyro readings across the tyre to get middle and edges within a tolerance so that's tyre is no overheating in any one spot.Originally posted by monkeycsl View PostMy pressures where 4 degrees hotter on the left side as loaded up more of the time,do you guys compensate for this by having less pressure left to right
rayer:
Depending on geo that might mean different pressures at each corner as you can't alter geo at track easily
As Barry did I set my pressures to 31PSI all round after a warm up lap.Originally posted by shimmy View PostWe tend to drop pressures to keep them 31-32 all round BUT tbh what you really need to do is check pyro readings across the tyre to get middle and edges within a tolerance so that's tyre is no overheating in any one spot.
Felt at those pressure's after about 10-12 laps (depending on traffic) my tyres went off a touch :bigcry:
The off was in a straight line. Last time at How Fast I said to you it felt wallowy, same again at Donny, maybe need stiffer springs as these are 80f 45r.Originally posted by shimmy View PostWAAAAAAAAAAAAAAAA
If I change spring rate I might aswell change the lot as I don't know whether the Nitron dampers would cope.
