Need tips for installing GT Splitter
    Hey guys,
    I ordered the GT splitter a number of weeks ago, all OEM parts except for a couple of bolts. Wondering someone has done the install and if they have any tips for the installation. I know that I will have to drill some holes in the bumper core support and I have the tools to do so. Just not sure about all the rest of it. Any tips would be appreciated.
    Originally posted by Drogo View Post
    Hey guys,
    Bumper supports that are pre-drilled came on most 95 and older cars. Might be worth just looking for a cheap early 3 series bumper.
      The mounting screws on the upper side are countersunk so you'll need to get/borrow a countersink drill head if using your reo (they'll foul and puah up on bumper skin if try using button heads or otherwise) - not any measurements sorry but the centre of the fastener lines up with the edge of bumper skin
      Done it on a few cars now and its a case of assembling and measuring about a million times, 20mm-ish hole saw in bottom of reo and then need to line up for upper holes
      Hard to explain the process as i never taken any decent photos for this purpose
      Sent from my SM-G930F using Tapatalk
        Oh and you need to chop reliefs in the bumper, ill try find pics and post them up
          Also need to cut reliefs for the supports in the bumper, ill look for pics and post up
          All the shields and ducting fitted as per pic
            Very much appreciated. I will have a much better idea of what situation I am in when I take the bumper off. At the moment car is in storage cause Canadian winters a great.
            Have you ever had any issues with the splitter tilting forwards? I have a good idea of how that can be adjusted, just wondering about your experience with it.
            Also, That build is amazing. Respect.
              I will look out for this, thank you. I have a '97 North American Spec M3, maybe my bumper is pre-drilled. I have not yet taken off the core support to have a good view of it.
                Havent had an issue that it tilts forward, interested in the adjustment you mentioned though as once its bolted in theres not anything to adjust in that respect. Just thinking that is most likely installer error with mounting hole placement? Unsure
                  Was thinking that if something like that would happen, some strategic washer placement would help.
                    Once you get it together it'll make more sense that itd be hard shimming it out - need the whole front end off to work out mounting points and get it aligned correctly with the lower lip and 'mustache' corner bits in place
                    Additionally, and you may not have this issue (US market car i assume?) Is that the centre support fasteners are NLA so i had machined up some copies of mine to use, as the sprung jobs foul quite badly on the oil cooler duct (Pic #2 on right - USDM cars missed out on our euro complications)
                      What undertray is covering the x-brace and surrounding area? Is it oem?
                      I've been trying to find a part number, but can't find it in any diagrams on realoem.
                      Found the part numbers.
                      51712491567
                      51712489775
                      Look to only be available in Europe, expecially the larger cover. Would love to get a setin the US for track purposes.
                        51712491567
                        51712489775
                        Yeah my original oem one, theres 3 pieces; large centre part, rhs is an aluminium shield that goes over the rear lollipop and lhs is a plastic version
                        Was considering making a crp version as its very specific and quite different from pre mid 95 and post mid 96 versions. In process of building shed etc so its a while off
                          Kthree
                          I did it.
ID:	150876 Click image for larger version
                            Looks good!
                            Sent from my LM-V600 using Tapatalk
                              More pictures on the car
ID:	151173 Click image for larger version
