E36 camber plates with no hassle?
    What type of camber plates would I be able to get for like $250 and not have to constantly tighten and adjust? Thanks.
    As a fellow person who does not have the largest budget, it is better to pay up for the right quality. Or buy a good brand name used
    What camber plates do you have right now that are not working?
    Build Thread:
      I don’t have any right now, someone I know whose raced and drifted a long time told me not to get ones that have to be adjusted constantly, thank for a reply.
        Vorshlag or Ground Control are the two quality ones. With Vorshlag being overall preferred by many. I have Ground Control, both are high quality. Turner also might have some
        When you order them new or source used one you will need to consider your shock, as well as the springs diameter you are using. If you are using a common shock and racing springs it will be easier to find a used pair since everyone else has it.
        Something else to consider is when you remove the stock rubber mount, you will be putting the same or more force on a smaller area with less energy absorption/damping. So you will increase the pressure and possibly the force on the tower, it's a good idea to get the factory reinforcement plates.
        Even used $250 is quite a limited budget, but hope you find something shopping around.
        Build Thread:
          Thanks, I’ve been looking at turner fixed plates also, but all of them just say fits m3. I’ll look into those brands
          edit, I have h&r oe sport springs and Bilstien b4 shocks
            Dinan fixed plates on ECS come out to excactly $250 lol, I may go with those, I have more money to spend on them than that but you never know what could come up with a 30 year old car
              Fixed with your setup would make a lot of sense. I wouldn't invest in really nice adjustable plates as youll probably out grow what you have in due time. I was assuming you had a setup a little more modified.
              Build Thread:
                Yeah it’s my first car and it’s my daily currently but I wanna take it to VIR this year and I’ve done some autocross and seen the edge of the tire suffers from too little camber
