[DIY] Front Control Arms & Bushings
    I was experiencing some clunks & clanks from the front of my car over rough pavement, especially the right side. Since the front control arms were about the only major part that had not yet been replaced, I figured I would see if that was the cause of this mystery noise, & it just so happens that I was correct. I had trouble finding a decent write up--my trusty Pelican Parts technical articles failed to yield pictures--so I thought I'd produce one to make this as easy as possible for anyone who was unsure about tackling this. Let's get started...
    PREP WORK
    What do I need?
    Here's a picture of almost everything I needed:
    Items, as pictured from left to right:
    -Shop towels
    -Q-tips
    -Control Arm(s), P/Ns 31122228461 (L) & 31122228462 (R)
    -FCA Hex Nut 1, P/N 31121095420 (x2)
    -FCA Hex Nut 2, P/N 32211095267 (x2)
    -PB Blaster
    -White Lithium Grease (or WD40)
    -Loctite Blue (medium)
    -Dimple Pin
    -Rubber Mallet
    -Pickle Fork
    -Small (Craftsman) Gear Puller
    -Standard Steel Hammer
    -1/2" Sockets (deep are preferable), 16-19, 21 mm
    -1/2" Ratchet Driver
    -Open-End Adjustable (17 & 19 mm combos would have been ideal)
    -Torque Wrench, rated to at least 80 ft-lbs
    Not Pictured:
    -Jack
    -Jack Stands (pair)
    -Creeper/old skateboard
    Now that we've got everything we'll need, let's get down to business.
    STEP 1: POSITIONING THE CAR
    The goal here is to get the front of the car up on jack stands with sufficient room to work underneath. Here's what I've found to be the quickest way, especially with a car that is lowered a good bit:
    0) Break lug nuts free, but do not remove them.
    1) Jack up the right side, using the rear right jack pad.
    2) Place your first jack stand on the lowest setting possible underneath the right front jack pad location.
    3) Release jack. Yes, your car will be pivoting on the left rear wheel & the jack stand...
    4) Slide jack in from the front & raise the car using the front subframe crossmember.
    5) Insert left jack stand.
    6) Raise each stand to the desired height, making sure that both sides are equal, & lower the jack so that the car rests on the stands. Remove your front wheels. For the time being, you can leave your jack under that front crossmember with light pressure for reassurance.
    When you're finished, it should look like this:
    STEP 2: OLD, TIRED FCA REMOVAL
    Here's a look at what we're replacing:
    With the wheel removed, turn the steering wheel such that the rotor is pointed inward. We will first remove the (17 mm) nut from the outer ball joint:
    You won't be able to remove it completely, but loosen it until it almost touches the bottom of the strut. It shouldn't be too hard to break free unless you're dumb enough to use a stubby open end adjustable, like myself.
    Next, we need to pop the ball joint free from the hub assembly. There are two ways to do this.
    The first way will be to use our pickle fork, jamming it between the hub knuckle & the control arm:
    Take your hammer and force the pickle fork's wedge to separate the joint; it will take some persistence with that hammer. THIS METHOD WILL DESTROY THE BALL JOINT. Don't plan on reselling these suckers for more than $5 combined.
    Can't seem to get that thing to budge?? Well, luckily for you, there's a second way to go about doing this. I couldn't get that pickle fork to pop the joint for the life of me, so I removed the strut from the hub assembly. It is attached by 3 bolts: 2 at the bottom, which go directly into the hub, & a third bolt that goes through the "branch" that extends out of the top of the hub. All 3 of these bolts are 18 mm. Before you do this, though, pull the brake line & co. out of the bracket on the strut body. In addition, place your jack under the brake rotor for stability, so it doesn't flop around.
    Here's another visual aid:
    Now that we have better access to that ball joint, push the strut inward away from the hub. Using your gear puller, set the pin on top of the ball joint bolt & the two arms down under the hub knuckle, like so:
    Now take your 16 mm socket & tighten that gear puller. Make sure the arms seated well under the knuckle; once you're ready, crank it down until that ball joint pops. & boy, will it pop...
    You should now have something that looks like this:
    Reattach the strut to the hub, but don't torque it down. We're just putting it back on for stability as we move in to the inner ball joint. Before we get there, though, let's remove those two bolts that are holding your FCAB housing ("lollipop") in place, using your 17 mm socket:
    Moving right along, let's remove that inner ball joint nut. You have two access points: firstly you can try reaching around where the subframe meets the main rail & working blindly, or you can slide under the car from the front & perhaps get a look at what you're trying to do. Here's a quick visual of where you'll go in from (above the steering rack & PS cooling lines):
    I apologize, but I couldn't really get a picture of the nut location. It's up there, I promise! Anyway, remove that nut with your 19 mm wrench...
    For this joint, you really don't have any choice but to use your pickle fork. Insert like so:
    Hammer that sucker in there. It'll take quite a few whacks, probably, but it'll go. It shouldn't be as stubborn as the outer joint. Once it pops, the entire arm will fall to the ground. If you'd like, have some bubble wrap on the ground to keep from hurting your floor or the arm.
    Now that the old arm is out, you should be left with this little dilemma:
    Your first step is to take note of how far the bushing is pressed onto the arm; upon re-installation on the new arm, you'll need to press the bushing to the same location on the arm.
    Using your dimple pin, press a small dimple (duh) into the center of the end of the control arm on which your bushing is mounted. This little 'crater' will keep the tip of the gear puller from sliding off the control arm as you pull it off.
    Next, take either your WD-40 or your Lithium grease & apply it to the shaft on the control arm, where the bushing will slide off.
    Now, using that gear puller, fit it onto the end of the control arm and the bushing/housing. Take your 16 mm socket & go to town. You'll either pull the housing off the bushing, or the bushing off the control arm. If you're replacing the bushings (highly recommended), then you'll need to separate all 3 pieces either way.
    Here are a few pictures of how to press the bushings out of (or into!!) the lollipop:
    Be creative... as you can see, I used that washer to dissipate pressure across the surface of my aftermarket bushing. Something like this will be necessary to a) prevent damage of a new bushing & b) give you a surface on which you can place the gear puller tip, as there is a hole in the middle!!!
    **NOTE: If you are using an offset bushing like I did, be sure to press the bushing in such that the hole is closest to the "handle" of the lollipop. Look at the pictures above for reference.
    Now take your new arm & grease up the end, where you'll slide the bushing on--a little grease on the inside of the bushing isn't a bad idea, either.
    Finally, take your rubber mallet & tap the bushing onto the end of the arm. The "handle" of the lollipop should point in the same general direction as the opposite end of the control arm (see picture below). Once it is started & aligned, feel free to hit it a bit harder. Don't be too shy, or you'll never get it on! (Best advice ever?? ) As you approach the spot you had hopefully taken note of when you first removed the bushing, ease up a bit. You should get it as close as you can to the original location.
    Your final product should look something like this:
    This is more of a quick & dirty guide & may not be effective for those with stock bushings, but it is just one more option. The guys at Understeer.com have a pretty thorough DIY for stock bushings, as seen here.
      Reserved for reinstallation DIY.
        Nice job Zach!
          Nice man! I need to do this sometime this summer
            Originally posted by Braymond141
            Nice job Zach!
            Thanks Brett, always nice to get your stamp of approval.
            It really isn't bad as long as you have a decent guide to reference ... once I'm finished, read this through a couple times & you can do it in 3 hours total I bet. The first one took me forever between trying to take pictures for the write-up & wasting time with the pickle fork on the outer ball joint, but I did the second one in about 80 minutes, using that POS open-end adjustable.
              Oh no, I'm not afraid of the job by any means. I know I could probably have it fully finished in a little over an hour (i'm an expert at popping ball joints ). The sad face was for the cost of OEM LCA's + whatever bushings I go for, lol.
                Ah, gotcha...
                  This DIY will still be VERY helpful for me, though.... so thanks for doing this!!!
                    Not a problem. Let me know if anything isn't clear enough. & of course I'll have the other parts tomorrow, I was just too tired to finish 'em tonight.
                      No biggie. Maybe I missed it, but are you changing the FCAB's too? If so, which ones?
                        I had already done my FCABs, but I'm gonna do a mini-DIY (see reserved 2nd post). I went with the offset (95 style) TCK bushings.
                          hmm... you should do a mini write up on which ones are better and why
                          jk jk
                            I'll definitely include some thoughts on the the different choices
                              Very nice!
