I've had issues with mine. The solution is to convert it to manual. I've estimated that the total cost should be about $1,000.00 USD. The parts are approximately $400.00. The labor should be about six hours.
If you want details, let me know. I have a nearly complete parts list and can go into exactly what needs to be done. Mine should be converted in the next month or so.
....I have already taken action to buy this part: 1,2,3,4,5,6,16 (Click here)
but where I find these parts (look image below)? The 2 and 3 (look image below) are already mounted on my gearbox? And other???
thanks for any reply
Parts 2 and 3 may be on your transmission already, as you say. I reread one of the threads that I based my parts list from and one person states that some parts may not be needed.
However, I would buy them anyway. They aren't expensive and the parts may vary between the SMG and fully manual versions of the gearbox.
Did anyone find out if you can convert the existing box? I'm looking at converting mine but dont fancy forking out 600 quid for a manual box if i dont have to!
Well i finally found a mechanic that will do the work for me , an he says it should work out fine...
The way it bascially looks is an manual gearbox with all the SMG **** bolted onto the side of it....
1. Drop the transmission. Two holes must be drilled into the bellhousing in order to install the first six parts listed above. See these pictures for details:
2. Cruise control clutch switch must be connected for vehicles with cruise control.
3. Unplug fuse 28-SMG supply. Do not unplug the SMG control unit. The vehicle will not start. This info has been posted identifying two different fuses: 2 fuses: #111 and #26, one is on the fusebox, other is behind the smg pump. I do not know which is correct.
4. Unplug the connections to the SMG display on the back of the instrument cluster Optional: the cluster SMG display can be converted to an oil temperature display.
5. Optional: the smg display area in the center console can be changed to a storage pocket. Part number for the storage pocket : 51161977231
