Originally posted by K.Dickie
DIY: HomeLink + auto dimming rear view mirror retrofit.
The connector I bought (part bumper flagged at the beginning of the thread http://www.ecstuning.com/ES79472/ ) didn't have the wires inserted into the plug. I was hoping someone who has done this could snap a pic of the back of their harness that plugs into the mirror's harness.
Just finished this mod yesterday. Definitely happy to have this update in there! I did find the pin outs, but it was on another forum. Here's what I used:
Pin
1 + Reverse
2 Not used
3 + Switched
4 Not used
5 Not used
6 Not used
7 Not used
8 + from alarm LED
9 - from alarm LED
10 - Ground
Hate to resurrect such an old thread but I hope this might be useful to someone.
Yes did the retrofit.
A year later, developed a parasitic draw. After tracing it, you guess it, fuse 01, which is dedicated to the sunroof only!
The homelink instructions are very straightforward. pin 3 violet/white is the switch power and the brown is the ground. I mess up a bit in the sense that I couldn't remove the map light assembly connector from the sunroof down (you just need to pull really hard since it snaps in), so I connected to the SAME wires from other the plug that is covered in the pink tape (see picture below). Yes if you remove the pink tape, the same colors wires continue from there.
Now that I know how to remove the map light assembly, I'll try to connect as illustrated from the instructions. Somehow the way I did it, I must have caused shortage.
I removed fuse 01 for now. Battery no longer draining.
Will update this post when I figure out what happened.
Try to follow directions guys. Trust me, you dont want to kill your battery. Installation is pretty simple and straight forward but dont cut any corners (no pun).
Javier
