Some information for anyone looking into H&R OE Sport springs (perches, hats)
    Last week I took a ride up to lend a hand installing some new Konis and H&R OE Sport springs with Numik on his M3. The rear install (which I didn't help with) went smooth, but after we pulled the front assemblies apart and attempted to fit the H&R springs upon reassembly, we ran into an issue.
    Take a look at the stock 1996+ M3 spring with the upper 1996+ perch sitting on top of it...
    Now take a look at the 1996+ M3 spring perch on the H&R OE Sport spring.
    Does anything look odd to you? Probably not from that picture, as the perch is centered. But i'll tell you that it doesn't sit on the spring with anything close to resembling a nice tight fit. The diameter of the spring is too large for the perch.
    Here's what happens if you shift the perch to one side. See how much play there is in it...? (No, the spring is NOT upside down)
    That's nearly enough room for the coil to slip by the perch. With enough use, and enough force, I wouldn't be surprised if part of the coil jammed itself up over the edge of the perch. Here's a look at the spring pad without the perch in the way...
    Now...a quick look at the H&R website.
    (Link: http://hrsprings.com/scripts/appguid...20BMW%20|%20M3)
    Note that they specify "large front hat". Numik actually contacted H&R about this and was told that the springs were designed very early on when the 1995 M3 was on the only one on the road. 1995 M3's have larger top perches (what H&R is calling hats) than 1996+ M3's. They never went through a redesign to have a spring that's designed around the 1996+ upper perch. I wasn't aware of this, and in calling a few other guys that have done a lot of suspension swaps, it seems not many people know about this.
    In short...If you have a 1996+ M3 and plan on running H&R OE Sport springs, you will need 1995 top perches in order to run them safely.
    No ****... that's pretty damn off! I wonder how many people have them install without paying attention to something like this. Thanks for the heads up
      this really isn't anything new, been known since 96 lol.
        good info
        anyone have an exact measurement of the spring rates on the HR stuff? front and rear, Sport, OE Sport and Race
        they don t give out that info, which is stupid IMO
          Sure hope you didn't install them with the 96+ spring hats.
            Probably a lot of people man. Hence the thread. Kinda crazy, huh?
            Actually...there are 2 new things going on here that are new to a lot of people (including myself).
            1) Finding out about the upper spring diameter of H&R OE Sports.
            2) You being a complete ****.
            Of course we did. The car handles great. After installing with the incorrect upper perches, we took the car down the turnpike and killed a new Civic Si off the line at 3 different stoplights. After that, we hit a highway off ramp and the car gripped so hard the tires were squealing. It was amazing. There's no way the car would've been able to do those things before the spring swap.
              Thanks for the heads up Nick - I know that I've been around for a while, and I've personally never heard of this issue before. Good stuff!
                I've never heard of it either
                  wow, just saying a minute search on bf.c would have given you all the info you need on OE sports. The cars are 11 years old, at their newest, I don't think we're going to find any revolutionary news at this point.
                    Searched on bf.c for a good five minutes and came up with nothing--at least on the M3 forum.
                    Thanks Nick.
                      I just recently became aware of this issue this year, but good to have it clearly and succinctly posted for future searches on the subject! I may personally end up going the Eibach route anyhow though after reading Tirerack's comparison review on both.
                        .. So is the hoom riding the bus until the new perch's arrive?
                          If anyone already knows of a good source for 95 M3 front perches now would be the time to post.
                          The Koni/H&R Sport install is about 3 weeks away for me....glad I ran across this post.
                            just get some new ones from CMUZYY off BFC, or get some used ones off of a forum
                            Part # 31 33 2 227 348
                            96+ Upper Spring Plate
                            Part # 31 33 2 227 903
                              Just saying man...i've met a lot of E36 guys, worked on a lot of cars, talked a lot of shop with people. I've never heard of this before we dealt with it. I suspect there are people out there that install the springs with the wrong perches.
                              I took the time to take some pictures of the issue, and make a thread so people can benefit from it. Mind you, this isn't even something I was doing to my car. This thread is solely here because it's highly probable there are other people out there who aren't aware the problem exists. Note that I even added a few key words in parenthesis to make it easier for people to find. If you can find me a thread on this topic here on the forums, you can LOL at me and my unnecessary thread all you want. But this it NOT common knowledge in the E36 community.
                              You're historically a nice guy and very helpful. But I took your post as a holier than thou **** comment. -1 for that man. You're not normally one to stoop to that level. Anyways, lets move on.
                              Yeah man. Scary that there are likely people running around on the wrong perches. Hopefully this helps someone.
                              Thanks Nick.
                              me too man.
                              Thanks man.
                              We put the stock springs back on The Hoom-mobile. He needed the car back on the road, so we put it back together with the new Koni inserts and the stock springs. I didn't get a chance to drive it, as when I left he still had to pull the rear H&R springs out and replace with the stock M3 springs for good measure. But it should be cool to take his car out in comparison to mine and yours with the fresh Sachs.
                              Weekend of the 25th dude.
