Some information for anyone looking into H&R OE Sport springs (perches, hats)
    Every OE Sport vendor site I've seen states they require the '95 Spring Hats. I'm not trying to be an a$$, just stating that this requirement is no secret if you are shopping for these springs. Buying used I could see the perch swap easily catching people by surprise.
    btw Spring Hats are about $20.
      Originally posted by OahuMPower
      just get some new ones from CMUZYY off BFC, or get some used ones off of a forum
      Part # 31332227348
      -thx
      Bav Auto has these as well for $10 something each for anyone that needs them.
      baba booey
        +1
        unfortunately, however, it's not documented well on the forums. thanks fiveightandten.
          + another for this.
          From tirerack.com, for example:
          http://www.tirerack.com/suspension/S...lar=&brand=all
          Note: Avg Low .75"F .30"R
          Large front spring hat needs to be used in conjuntion with this spring kit. Can be purchased through dealership. The required hat is the same one used on the '95 M3. Excludes Cabrio
          <- has sammy's old Konis
            http://forums.bimmerforums.com/forum...ght=OE+Springs
              Here are the spring rates for E36 M3 aftermarket springs.
              Spring -> Front Rate -> Rear Rate
              Stock E36 M3 ->105 ->335
              LTW E36 M3 ->138 ->402
              Eibach Pro Kit M3 ->148 ->428
              Sachs M3 coilovers ->215 ->395
              H&R 29910 (OE & Sport) ->200 -> 380
              H&R 29910 DTM(Race) -> 345 ->515
              H&R Coilover ->340 -> 380
              Dinan ->150 ->400
              Vogtland 3.2L M3 ClubSpec -> 183 -> 460
                Dinan ->150 ->400
                Good work there. Anyone know the Euro M3 value? Also, are all these progressive springs?
                  Originally posted by fiveightandten
                  You're historically a nice guy and very helpful. But I took your post as a holier than thou **** comment. -1 for that man. You're not normally one to stoop to that level. Anyways, lets move on.
                  Well somebody better tell Bruce Springsteen to get a new nickname because apparently Nick is THE BOSS now!
                    Sorry to bring up an old thread but are the guide supports (strut bearings) off a 99 coupe compatible with the upper spring perches off a 95?
                    My question is if im ordering an upper strut perch off a 95, do i also need the bearing off a 95 to fit with the perch? or are the bearings for both the 95 and the 96+ the same size?
                    also. any problems with camber running OE springs?
                      bradley
                      styick with your current '99 strut bearing (number 1) and just get spring hats from a 95 (8, which is the rubber pad, and 9)
                        Forgive me for the old thread bump, but are the bottom spring pads different between 95 & 96+ years?
                        On my 98, using H&R OE Sport springs, can I use the 96+ lower spring pads (PN: 31331124322), '95 lower spring pads (PN: 31331124322), or can I use either?
                        Ugh. Just answered my own question. Gonna post anyway in case it helps someone else down the road.
                          Lol. Department of redundancy department.
