Overpriced exhaust hangers!?!?
    Does anyone know of a cheaper option for the catback exhaust hangers? I don't want a cheap product, I just have a hard time paying $52 dollars for a piece of rubber attached to stamped sheet metal. I priced mine at Bavarian Autosport mainly because I like dealing with them. I understand that there are many of you with quite a bit more BMW experience than myself, so I was just checking. Let me know what you think, and thanks for the input!
    you should be able to get Lemforders for like $35. Don't get the $20 ones from Pelican or RMEuropean. They don't last long at all.
      You get what you pay for, You drive a BMW M3, spend the $ on the Lemforders !
        Best source for Lemforders?
          All you have to buy is the rubber portion. Your existing sheet-metal slides off the old ones.
            I have the cheap-azz pelican elaplast ones and they're holding steady after 6 months with the rsc36. They were metal reinforced.
              autohausaz.com
                the rsc36 is also 20lbs lighter than the stock anvil.........err, I mean exhaust
                  Turner has them for around $35..
                    Thank you everyone for your help!
                      Does anyone know where I can get Lemforders? I have search the internet and come up with nothing.
                        I found the actual german site, however is there a US distributer that sells them?
                          Do not use bavauto. Only lazy people shop there, they are more overpriced than the dealer in a lot of cases. No thanks
                          getbmwparts.com, bimmerparts.com, etc.
                            Look into this mount. Significantly cheaper, and actually retains it's position when load is applied.
                            http://www.napaonline.com/Search/Det...+50006+2006032
                            Part Number: BOS 255070
                            Application Information: BMW M3
                            Engines: 3.2 L 3152 CC L6 DOHC
                            Comments: E36 Body
                            If you want OEM; www.realbmwparts.com is now the cheaper source over www.getbmwparts.com
                              ya that mount is definitely a good option
                              unless you like buying exh hangers every 3 months
