We know that the 1 piece plates are better. Calvin (OahuMpower) was simply saying that the bw 3 piece plates will work fine. Being new here, you probably didn't realize that Calvin actually provided input in the design of the AKG 1 piece product. He actually provided a pocket from a wrecked car to design the prototype..........
Rear Trail Arm Pocket Repair seeking advice
The BW 3 piece setup allows you to position the plates around the welds with a bit more freedom. In my car, for instance, the factory welds were built up a little too large for the 1 piece AKG plates to fit on without removing some metal to enlarge the holes. If I had the BW plates, I may have been able to just space them slightly farther away from one another.Originally posted by xmetrixI say the 3 piece reinforcement is garbage. pure and simple. I've had a set, its just such a worthless mess. Why is it 3 pieces when 1 piece is superior?
Go with the 1 piece. its a whole lot cleaner and straight forward repair. They're $50 at akgmotorsport.com
I didn't bother shopping around for the cheapest. I just needed it done.
I went to castro's customs and paid around $400 for new bushings and labor to install everything.
More install pictures available at xmxstudio.com/rtab_repair
The single piece kits just offer a nice uniform no chance of ****ing it up type installation. Makes the job take a whole lot less time as it only takes 2 tack welds to get it secured into position rather than messing with 3 seperate pieces.
I had bolts rip from the chassis and everything went back together like a neat clean puzzle piece. rear end felt great after everything was bolted back up.While you're getting that done I'd recommend doing all your rear end bushings. subframe/diff/rtabs/etc.
In most cases the AKG plates are better. But there are cars where they're a little tough to position without some coaxing. I did all the prep on my car and I was side by side the guy who did the welding through that part of the job. He said he prefered the BW plates from an install standpoint. I preferred the AKG plates and I was fine putting them in the car. To each their own. But IMO, the BW plates aren't "garbage". Just a different design.
