My clutch stopped working today. I think I have a good idea what to check but but I wanted to run it by the forums here to be sure.
There were no warning signs leading up to this -- when I went to drive to work the pedal was incredibly easy to push, but it stayed depressed and the transmission wouldn't go into 1st gear.
I looked at the basics - there is no fluid anywhere (that I can see) and the reservoir is full. I had basically the whole clutch system replaced last year, including the flywheel, master cylinder, slave cylinder, detent pins, etc. and it has run like brand new from then until yesterday.
I was going to check the hydraulic line between the cylinders and re-bleed it. Is there anything else I should check?
Thanks,
Mark
Thanks,
Mark
