Nice!
Back with a Tech
i want to get a switch like yours to override the electric fan. I'm not very good at wiring so i tried once and gave up. I've got the mechanical and aux fan deleted and then a spal fan wired up to the stock wiring to kick on as the aux fan normally would (also with a lower temp fan switch) BUT it would be nice to manually turn the fan on, like when idling prior to an autox run or heavy traffic.
Thanks! I was reading about some guys Euro Delivery yesterday and he was saying you met him at the Nurburgring for a while, freaking awesome.Originally posted by M_ParallelNice!
Thank you, the sedans are nice but I prefer the look of a nice clean coupe, and I have two sedansOriginally posted by westopher****ing stunning. Makes me want a sedan so badly.
The override switch is really easy to wire for the fan since it is only sending a ground. If you figured the fan relay out this is really simple. I used the ground from the cigarette lighter on mine and tapped into the temp sensor wire. You just have to figure out how you want to wire it through the firewall.Originally posted by camdinans3i want to get a switch like yours to override the electric fan. I'm not very good at wiring so i tried once and gave up. I've got the mechanical and aux fan deleted and then a spal fan wired up to the stock wiring to kick on as the aux fan normally would (also with a lower temp fan switch) BUT it would be nice to manually turn the fan on, like when idling prior to an autox run or heavy traffic.
We need some more of your Avus!Originally posted by andreialtadroool
I know I know...It is something that will eventually happen. I foresee myself owning this car for a long time so I'm not in a rush. Once the auto becomes boring I'm sure I'll do it.Originally posted by westopherJust tranny swap it and keep it as is forever. Its a ****ing perfect car.
Gluttons for punishment I guessOriginally posted by M_ParallelHaha for real.
2 verts for me, 2 sedans for you.
Thank you!Originally posted by lancemacBeautiful sedan.
Originally posted by Vintage_Nice OP. My favorite color on these. A guy up the street from me has the same combo with manual.Thanks for the kind words guys!Originally posted by dynagrooveGreat thread Cblock. I really like your photos and documentation of the journey of this car. Keep up the good work!
Originally posted by cblockNice sedan! I recognize your car from bimmerforums but surprised I've never seen it out and about. I'm pretty sure I'm going to the BMW show at XXX this next Sunday, maybe I will see you there.
It's a garage queen now I want to go but I have to work, but I am going on the hurricane ridge drive!
