Car idle and acceleration hesitating
    Oh yeah, get that light read and I wouldn't put any more money into it until I know what it said. And I'm not sure about the flash to see you either all I know is stuff from when I used to have a turbo DSM
      Here's what I found when I read the errors. I don't see listed anything denoting what error code would come up if read with a Peake scanner.
      I'm not sure what this device is that it's referring to?
      Second pic shows the second O2 sensor appears to be bad? My pic is cut off at top so I don't know what that top error actually is.
      On a side note I did find one small vacuum hose unplugged when I crawled under the car yesterday. However it did not help. In fact things got worse when I plugged MAF back in.
      2007 M6
      2003 M3
      1998 M3
      2011 Ducati 1198
        A bad 02 can make your car run like shit too. Swap then around and see if you get the error to follow the bad sensor
          Just swapped out the 2 pre-cat O2 sensors as I didnt have more than just 2. So far no change in performance.
          I also changed out the cam position sensor, IAT sensor, engine coolant temp sensor, MAF, and i have a crank position sensor to install when I can get on a lift.
          Olemiss540, where in the wiring is the resistor you found in the MAF wiring loom?
          2007 M6
          2003 M3
          1998 M3
          2011 Ducati 1198
            If I can't find a smoker for detecting vacuum leaks I may be forced to remove the intake manifold and just replace the gaskets. Do some cleaning, replace all vacuum hoses, etc. With the amount of miles i have on this car it might be prudent just to do it. I dunno. I need this car running better.
            2007 M6
            2003 M3
            1998 M3
            2011 Ducati 1198
              Still having this issue and it's actually getting worse. I asked around locally to see if anyone had a smoke machine to no avail. I keep telling myself I don't have time to make one and troubleshoot why mine isn't working. LOL!
              To date, I have replaced the following:
              Cam position sensor
              Engine temp sensor
              Valve cover gasket
              MAF
              Pre-cat O2 sensors
              IAT sensor
              Fuel filter
              Plugged one vacuum line
              I still have the crank position sensor to replace, but I don't think that's it. And I have the intake manifold gaskets to replace, but have been so busy on my e46 M3 and my daughters 318i vert that this car just sits in the garage. Removing the intake manifold is pretty involved but I hope it reveals something. The cars driving condition is worsening. Finally, to recap, the supercharger is off the car. But I had the problem even when it was on the car so it's not related.
              2007 M6
              2003 M3
              1998 M3
              1997 318 vert
              2011 Ducati 1198
                Assuming you've checked this given all the other stuff you replaced, but any cracks in the underside of your intake boot? They can be hard to see because the rubber is stiff and the cracks happen between the bellows.
                  Just checked and it's pretty tightly sealed. I liked the idea but unfortunately it didn't help me
                  2007 M6
                  2003 M3
                  1998 M3
                  1997 318 vert
                  2011 Ducati 1198
                    Vanos been done? Test solenoid?
                    Sent from my SM-N910V using Tapatalk
                      No actually. Never even crossed my mind. How could the VANOS cause this engine to run so shi**y like it is? If it's a possibility point me in the direction of what maintenance should be performed on it.
                        Have you scanned for codes? My case was different BUT I learned if the dme thinks vanos isn't working it will set the cam angle at 90 degrees or so and engine will suck a lot. Inpa is invaluable here to see what's going on as it shows you the values while engine is running.
                        Any issue where it clears up or runs better around 3-4k warrants looking at vanos. It advances around 4.2k but can affect the engine at all rpm because it controls the cam angle. It's a must do maintenance item.
                          Oh I see your codes, you would have vanos or camshaft errors.
                            I'll try pulling codes again today. Maybe something has changed because it's running worse than when I started this thread.
                            2007 M6
                            2003 M3
                            1998 M3
                            1997 318 vert
                            2011 Ducati 1198
                              2007 M6
                              2003 M3
                              1998 M3
                              1997 318 vert
                              2011 Ducati 1198
                              Can't hurt to service and test vanos anyway. My car had had the seal done and the timing was slightly off so it ran a bit better afterwards.
                              Also, injectors? Bad injector could maybe cause O2 sensor error. Also the other error looks like idle air valve, you said cleaning it didn't help, maybe it's fried.
                                I didn't see this last post until now...
                                But I started in removing the intake manifold to replace the gaskets and all vacuum lines anyway. I found this:
                                That o-ring is tore, but I didn't have any fuel leaks. Might be a good time to remove these injectors and get them flow tested and balanced/repaired.
                                Also while I'm mentioning my intake manifold can anyone identify this cable? It's electrical, and not a vacuum line.
                                I think the only way to remove it is to remove it from intake manifold. Looks like I gotta remove the black box from underneath the manifold?
                                Im hoping that doing this maintenance addresses my issue or at least helps...
                                2007 M6
                                2003 M3
                                1998 M3
                                1997 318 vert
                                2011 Ducati 1198
