The sedan engine that I rebuilt is having a couple of issues. When cold it starts better but crank time is a little long, maybe a rev or two longer than normal. When hot it will chug and make knocking noises and then start, and if I give it gas it starts fine.
Overall power is lacking, particularly at low rpm but even at high rpm it sounds like not enough gas, lots of air intake noise but not quite the power it should make, maybe off by 20%.
Have tried swapping with spares I have:
Coils
Throttle pos sensor
Intake air sensor
Fuel pressure seems okay but need better test
Fuel pressure regulator
Fuel injectors (did help some)
Oil looks good, very clear after 500 miles (dumped break in oil already after 25 miles and due to dump this)
I tried jumping the fuel pump relay with a 20a fused jumper per Bentley and the fuse blew instantly.
Not sure if the symptoms of hot start and power are related. The icv was bad as it had water in it and froze, so the one I have is from the junkyard but I cleaned and the car idles fine.
Seems like next steps are:
Compression test (my tester died so I'm ordering one)
Better fuel pump test
Triple check cam timing (did this when assembling but who knows?)
Swap battery with my car (sedan battery sat up but charges fine)
Crank pos sensor
Cam pos sensor
Get my in pa computer working and check codes but I don't think there are any (cel on from swap)
Thoughts?
Sent from my SM-N910V using Tapatalk
Coils
Throttle pos sensor
Intake air sensor
Crank pos sensor
Cam pos sensor
Thoughts?
