I am presenting to all of you forum members my 1995 M3 with 103,000 on the dial. It’s a 5 speed Cosmos/Champagne version with no sunroof. I am an Engineer, so I have been detailed about making this car and equally fun and reliable car. I built the car to be used for commuting with tolerance for the track, and it works excellent. I have had many compliment me for hitting that mark.
Since I purchased in 2008 (94,000 miles), I have gone through the necessary safety and common maintenance items to do run track days and autocross: cooling system, air conditioning, engine belts, clutch, transmission, brakes, battery, starter, and some of the electrical system. All of the mods listed were done at Munich Motorsport (South Windsor Connecticut), including alignment and corner balance.
I am estimating the car to be worth $10,000 (located in Metro-West area of Boston), and am asking you all of you to provide honest feedback on my estimation.
As of now, here’s the upgrades the car has:
Brakes
Stainless Steel Braided Brake Lines - Bimmerworld
Brake Pads - EBC Yellow
Rotors - OEM
Drum Brake Pads and Hardware – OEM
Backing Plates - OEM
Driveline
3.25 LSD M3 Diff (upgrade from 3.15 that was on 1995’s)
Shock/Springs
Coilovers - Bilstein PSS9
Camber/Caster Plates - Ground Control
Rear Shock Mounts - Turner
Rear Suspension
Rear Shock Towers - Rebuilt
Rear Shock Tower Reinforcement Plates - AKG
Rear Trailing Arm Bushing Pocket Reinforcement Plates
Rear Trailing Arm Bushings – Polyurethane 80 Durometer - PowerFlex (Purple)
Rear Suspension Subframe Bushings - Polyurethane 90 Durometer - PowerFlex (Black)
Differential Bushings – OEM New
Rear Swaybar Reinforcement Plates - AKG
Adjustable Rear Control Arms - SPC
Front Suspension
Front Lower Control Arm Bushings – Polyurethane Bimmerworld
Front Subframe Reinforcements
Engine Mounts - OEM
Swaybars
Turner Front/Rear Sway Bar Package
Adjustable Rear Swaybar End Links - Turner
Adjustable Front Swaybar End Links - Turner
Wheels/Tires
80 mm Wheel Studs
245/40/17 Dunlop Direzza Star Specs
Engine
Baffled Oil Pan
Crankshaft Scrapers
Connecting Rod Bearings - OEM
Oil Pump Nut Weld (stock pulley nuts tend to loosen!)
10W-60 Engine Oil
Exhaust
Refreshed O2 Sensor and Hangers
Transmission
40W Gear Oil – Red Line (BMW recommends thin Auto Trans Fluid)
Transmission Poly/Aluminum Bushings - Bimmerworld
Z3 Shifter (Longer throw = 15% throw reduction from stock M3) - OEM
ZHP Shift Handle - OEM
Needs:
Headliner
Instrument Cluster rebuild - $300 from Nichol’s Speedometer
Front Bumper Lip is damaged, but everything is intact and functioning
Rear Bumper has a scrape
Some on the rear trunk joint between the taillights, which is common.
Driver’s seat is cracked, but supportive. I figure most guys buying this car are going to put in Single Piece seats.
I also have
1 spare set of wheels (Contour)
1 set of winter tires (Michelin Pilot Alpin Sport 215/225)
1 full audio wiring harness
1 Stock Radio
Please PM me with any further questions. Looking forward to hearing from you all.
Brakes
Rotors - OEM
Driveline
Shock/Springs
Rear Suspension
Front Suspension
Engine Mounts - OEM
Swaybars
Wheels/Tires
80 mm Wheel Studs
Engine
Baffled Oil Pan
Crankshaft Scrapers
10W-60 Engine Oil
Exhaust
Transmission
Needs:
Headliner
I also have
1 Stock Radio
