Anyone know where to get the best deal on a factory OEM M3 spoiler for a 99 Coupe??? I saw some on eBay, but I am not sure on the quality??? Thanks.
Where to buy OEM e36 M3 Spoiler???
only palce to get OEM spoiler is the dealer. YOu can get an "OEM STYLE" spoiler any where else. FYI, oem spolier is easyer to install, the screw is close to the edge of the truck, they might also marked. After market spoiler is messy, you have to remove alotof sheet metal to install them. They might make one that fit in the factory hole.
FSR,
I bought my spoiler from Spoilerdepot.com. I bought it through Ebay for $112.
Paid them $70 to paint it for me.
It was easy to install, just had to drill 2 holes on each side in the trunk lid and mount it, and hook up the wires for the brake light!
Very easy to do, and it looks great!!!
Here's 2 pics of it.
There were no instructions on mine either for the brake light.
We drilled a hole through the trunk lid and used the rubber grommet to seal out any water. Then drilled another hole on the under side of the trunk lid and ran the wire through there. Then we hooked it into the brake light positive wire. Use a tester to find the correct wire. Take out the bulb in your rear window brake light, it will look better that way.
Let me know if you need more help. I can check mine out in more detail if you need.
Tim
I can't believe how good that spoiler looks on Firefighter's car for less than $200!!! I have been looking for one for my car, but it seems harder to find one without the light since my 3rd brake light is in the trunk lid (convertible).
Firefighter- DDid the paint match pretty well? Did they just ask for your factory color code and do that? I had looked at some on ebay but they were all close to $300 painted...I will definitely check out spoilerdepot.com
