M3 shakes?
    M3 shakes?
    i have a 97 M3 2 dr with 68,000 k that i recently purchased and the car slightly "shakes" when i lay down the pedal more than i should....this especially happens in 2nd gear. the car idles fine and seems to function fine when i drive it "less spirited." I dont have much experience driving M3's, is this slight trembling normal and due to all the horsepower, is it possibly the engine mount, or are there more serious possiblities? or am i just being paranoid!?
    Your car should be very smooth at any speed, at any jolt of the pedal. The only thing I can think of is that you've got some wheel hop going on. Usually thats only in first gear. Check your tire pressure. It should be very smooth in 2nd... just jolting you to the back of your seat. I suggest you take it into bmw, or to the dealer you got it from and get it checked up.
      Also, turn off ASC. The jolting your talking about could be the traction control coming on trying to keep you on the road. Is it possible your in an area where the roads aren't flat or clean and gravel is just sending your tires spining and traction control pauses your engine, then lets it fly free?
        It sounds like your rear wheels need balancing. Get them all balanced and it should clear up the problem significantly
          could be wheel hop also.. never know..
            It is not normal at all. Have your mechanic put the car ona lift and see if your Guibo, or "flex disk," is cracked and worn. This is a common problem, with the symptoms exactly as you describe.
              My mechanic just informed me that the right rear wheel is towed in a little.........in other words, i got screwed over by the dealer that sold it to me. Has anybody had the same problem, and how much did the damn thing cost????!!!!
              thanks for your replies guys!
