Any opinions on H&R coilover shocks vs Bilstein PSS9? How do these compare to Bilstein sport with H&R springs?
shocks: H&R vs Bilstein PSS coilover
they do make bilstein pss9 for the e36 because i have them on my car. i've never been in a car with anything other than stock or my bilsteins so i don't know how they compare. all i do know is that bilstein invented the shock absorber and is the top company in the industry. so my suspension is very good and has outstanding performance. other companies make just as nice suspensions and probably perfrom just as well. i did have to put spacers on the front wheels which isn't really that big of a deal with the package you get. you also relocate the sway bar link which doesn't affect the car in any way.
I talked to a guy who replied back from tms... he said that you can just that you have to do a couple other things with the pss9...
The PSS9 kit for the 325/328 will work but you will need to do a few things.
1. replace the sway bar links with ones from a 325/328, these attach to the control arm instead of the strut.
2. You will most likely have to run at least a 10mm spacer, but sizing of this spacer depends on the wheel and tire you have. This will require some clearance measuring on your part.
i think i'd rather get the H&R
