Who thinks the stock E36 M3 rotors and calipers are good enough for rigorous track use.
Let's take a poll on brakes:
Tell me about your ducting: $$, install time, where to get it, is it homemade?
I'm about to install porterfield pads. I've had metal masters on until now and high temp fluid. The car has been great so far on the track (5 or 6 days) but all those days were below 60 degrees F. How much of an improvement did you get with the ss lines? Did you reduce the fade or just the feel of the pedal?
Thanks!
SG M3- you are in Texas, so you probably have to deal with heat too. Being in so cal, hot brakes are a problem at the track. What kind of set up are you running? I want to upgrade my brakes as I am looking into forced induction, and want to make sure I can stop it fast before I make it go faster, especially in the heat.
. EBC pads ****.
