Is it normal that you would replace the rear more often than the front since they are rear wheel drive? Also, is it correct that the rear tires are a half inch wider than the front? If so we wouldn't need to rotate them right?
How often do you guys replace your tires?
Yes I believe that the rears do wear faster. Yes, on my M with Contours, the back tires are 245's and the fronts are 225's. And yes that means you can't rotate front to back. Also if you have directional tires then you can't rotate side to side.
Most of the tires you can't rotate. The rears prob get worn faster than the front due to power beign applied to the back. Also, alot of preformace tires are directionals, so, even with same size all around, like I run, you can't really rotate them unless you dismount them. You'll be lucky to get 25k+ miles from a set of preformace tires though.
I get about 10k on rears. Last rears that I got though only lasted me 3k. (1 month and a half). And I didn;t even burn tire or drive it too hard. The brand was Kumho. I think it was just that specific model though. I've had other Kumho's, and they lasted me 10k. I got them really cheap.
The fronts last me forever. I usually replace those every 30k.
