my trany is really sticky in my 96 m3, as in when i put it in gears you can feel its not smooth, almost as if rubbing against the synchro's. i re bled the system for airbubbles and still the same, when power shifting it has a tendancy to not want to go in gear in 2nd. also does anyone else's first gear whine in the rear end and the rest of the gears sound good?
sticky trany help anyone
My bosses 540s tranismission is like that, really grindy feeling. Someone suggested that the main ball below the shifter lever needed a good lubing....
Yes, my tranny whines in 1st gear as you get up to speed. So does my e21. I think thats just inherent of the trannys. You should hear the whining from my e21's diff... now, thats scary, sounds like a jet engine :P
I didn't notice any difference after installing the TMEs. My shifting has always felt tight and I like it. It's just a couple of things that bug me. Can't always get it into 1st and sometimes it feels like it doesn't want to go out of 1st??? This will happen every time if I'm in 1st and let off the gas and then push in the clutch. The entire drivetrain(?) shakes when I do this. It's not pleasant if I accelerate hard and let off the gas a split second before pushing the clutch
ouch. Is that normal???
I think I'll try the Redline tranny fluid.
I have the UUC SSK Evo 3 and it seems tougher than the stock shifter mechanism - maybe it has to do with that. I have the black TMEs as well and it didn't really help as far as the tight feeling when shifting. I think that's just the SSK and one of the few problems with it. I have the Redline fluids as well and I don't think it either helped or hurt.
Hope that helps.
