Car whistles.....any clue why?
    Me 2! Except mine is more like a tiny blow off valve! It only happens when Im power shifting....
    Maybe you're hearing the crankcase purge valve.
      I hope thats a good thing??
        Its the same thing you might hear when you turn the car off.. that quick hiss noise, some people hear it, some done. Its to equalize pressure in the crankcase.
          I figure if it is truly a bearing, then it will only get worse. Still only does it intermittently though. Still think mine may be the alternator
            Have you guys figured this problem out? I explained the whistling problem to the dealer and they also said it might be the pulleys and their bearings goin out. Just thought you guys might want to know. :beer:
              Theres a few common whistles/squeeks on the front of our cars.
              Most common:
              Whine: Alternator underload.
              Squeeking that 'pulsates': Probably a belt tensioner.
              Squeeking/grinding noise that changes with engine speed: Probably a pulley on its way out.
              If you can get the belts off, spin the idler pullies. If they feel tight and rotate around for only a few seconds or less, they are fine. Worn pullies will feel very loose and spin freely for awhile.
                It could also be your idler pully mine went out some time ago and it sounded like whistling/streeching sound.
                Oh you could have a s/c under the hood and just not know it.
                  do u have an aftermarket intake? when i get on mine directly after shifting and go at it the intake whistles nice and loud.. lol.. almost like a bov.. but at the wrong time i guess
