Steering wheel shake a hiighway speed can be a sign of bad control arm bushings.
I do have that problem. Just 1000 miles ago I had all 4 tires balanced with the road force variation balancing, and they all balanced out. And I still have the vibration at highway speeds. It starts at 70mph and gets a little worse the faster you go after that. This is weird. If I floor it on the highway, for the seconds that its accelerating, there's no vibration, but when I let go of the acelerator and the car jerks forward, the vibration worsens to a bigger level. After that, the vibration continues at a slightly less level.
Did I give you any clues as to what it might be? The bushings as you mention?
Is replacing those bushings an easy DIY in my garage over the weekend? Did you do all the work yourself?
