What is faster...???
    Are you retarded? They have the exact same engine block and components. Same displacement, same everything. The E46 is just improved with new computers and updated everything. Its the same engine, updated with a new name. Also if you cant pull a E46 to 60 in 4.6 seconds then you should not be driving one. Also if you cant run an E46 at 13.0 at 107 then you shouldnt be driving one. You need to stop reading codes and take apart some engines.
    no they dont.
    http://www.realoem.com/bmw/showparts.do?model=BG91&mospid=47433&prod=19980200 &btnr=11_1298&hg=11&fg=10
    http://www.realoem.com/bmw/showparts.do?model=BL93&mospid=47714&prod=20020900 &btnr=11_2987&hg=11&fg=10
    there are different part numbers for blocks.
    heads also have different parts numbers.
    youd be suprised at actually how many parts the s50b32 and s54 actually share, its a small number.
      Car and Driver rates the E46 M @4.8 seconds.
        i've seen most magazines list the m3 to 60 at 4.7-4.8 seconds. i don't remember seeing one that said 4.6 though.
          Chill. :wave:
          And as Serious said the engines are no way near as similar as you think they are. Yes, the displacement is the same, but aside from that, little is terrible similar.
          I too have heard the e36 evo with a 3.64 mated to its 6-speed will walk a little on an e46 m3..though I have never seen this run.
          -Richard
            S52 = same motor as a S54.... I think not, if so why didn't they send the Euro E36 motor over to the US because well its the same by your facts. The DEQ wouldn't let that motor over because of emission problems. Not because of the fact it has to much hp.
            Again look at the coding of the motor. 2 DIFFERENT MOTORS. 1 S52. other 1 S54.
              Chill. :wave:
              -Richard
              I would love to see that run.
              This to all non owners and newbies
              To all non owners and newbies listen and learn because assumption only makes an ass out of you and me and is the mother of all fckups:soapbox:
              eace:
